1978 - 1996 Big Bronco
Help, High Idle...
Old Jan 3, 2003 | 09:25 PM
fcarruth's Avatar
fcarruth
Help, High Idle...
Need some help guys. I have recently replaced my idle air control valve, throttle position sensor and thoroughly cleaned the TB with TB cleaner. Here is the problem. When I start it up, it starts normal but after about a second or 2, it seems like someone is pushing on the gas pedal pretty good. Very high idle for about a minute and a half then back to normal of about 750 RPM's. Did I do something wrong and / or is this a simple problem to fix ? The TPS is not adjustable or at least you can bot move it either way.
Thanks for your response. I want to fix this screamer this weekend.
Old Jan 4, 2003 | 02:19 PM
79_250RangerLariat's Avatar
79_250RangerLariat
Help, High Idle...
Did you reset the computer by disconnecting the battery?
79 250 Ranger Lariat 4wd 400 C6 3.55's 33x12.50 16.5's
78 Bronco Custom 4wd 400 C-6 3.50's 31 10.5 15's
66 Mustang Coupe Sports sprint 200 c-4 cruise o matic 3.00's
99 Grand Prix GT 230 ft/lbs torque out of a non turbo'd 6 cyl hehe
Old Jan 4, 2003 | 04:29 PM
fcarruth's Avatar
fcarruth
Help, High Idle...
Actually, this is one of the 1st times that I did not reset the battery. I'll do it and let you know.
Thanks
Old Jan 5, 2003 | 12:09 AM
spixican07's Avatar
spixican07
Help, High Idle...
is it cold out? that may just be the computer warming the engine up. mine does it slightly when its warm out side but when its down under 50 or so it really humps it for a minute or two until it reaches a temperature the computer likes.
Old Jan 5, 2003 | 09:17 AM
fcarruth's Avatar
fcarruth
Help, High Idle...
Resetting the computer looks like it did the trick. Glad you all check this thing out on the weekends pretty often.
Thanks again for your help you two.
Old Jan 5, 2003 | 01:05 PM
ryanguglich's Avatar
ryanguglich
Help, High Idle...
