Decoding the numbers
Old Feb 1, 2007 | 11:45 AM
ss3964spd's Avatar
ss3964spd
All,
The tag on the inside of the drivers door opening lists various information. I did not see anything that would indicate what engine is installed - although I assume that it's the 302. I did note that "Trans" has a code of "U", and "Axle" has a code of "H9". "Tape" (what the heck is that?) shows "A".
Anyone know what the U, H9, and A decode to?
Thanks,
Dan
Old Feb 1, 2007 | 12:48 PM
aircraftfixer's Avatar
aircraftfixer
click on the link at the top of the page Articles/Specs and click on vin decoder and type in your vin number see if this answers any of your questions
Old Feb 1, 2007 | 01:24 PM
ss3964spd's Avatar
ss3964spd
Thanks Fixer, I found the decoder after I posted the my first message.
The only thing that it confirmed is that the truck does have a 302. Still would like to know what the other codes are.
Regards,
Dan
Old Feb 1, 2007 | 01:49 PM
andym's Avatar
andym
The vin won't tell you anything about the tranny or the axles.
U means it's an AOD tranny.
H9 means it's a 3.55:1 limited slip axle.
I honestly have no idea what TAPE is.
Old Feb 1, 2007 | 02:08 PM
ss3964spd's Avatar
ss3964spd
Thanks Andy.
Don't really know much about the trans, although I did know it is a over drive automatic.
Any particular AOD model?
Old Feb 1, 2007 | 02:15 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Besides paint codes, there are now (pinstripe) TAPE codes.
Take the TAPE code, go to the section on tape and there it is. Before they had those codes, it was a b!tch when a stripe was needed for a body shop...there was just a jumbled mess in the parts catalogs when lookin' one up.
Old Feb 1, 2007 | 03:30 PM
andym's Avatar
andym
AOD *is* the model of the tranny. It does stand for automatic overdrive, but that particular tranny actually goes by the name AOD.
Old Feb 1, 2007 | 03:36 PM
ss3964spd's Avatar
ss3964spd
Oh.
LOL, thanks Andy. I've seen references on this site regarding automatics, calling them several different combinations of letters and numbers; AOD, EAOD, E4AO, PITA, SOB, POS, etc-etc.
So, for a '95 F150 4X4 with a 302 the standard automatic transmission is known as the AOD.
Got it!
Numbers - I couldn't find any section on the site called "Tape".
Dan
Old Feb 1, 2007 | 03:44 PM
NumberDummy
Smile C5ZZ 6520000-AA first stripe kit ('65 Mustang GT)
TAPE was added in the 1980's so us dummies could figure out the myriad stripe kits. Ford initially listed the stripes in the body sections of the car parts books in the mid 60's. Half didn't have pictures and the descriptions were useless.
Having a TAPE code on the VIN plate ended the frustrations of looking for a stripe kit..it works just like a paint code. You take the code and go to the stripe section...it made a impossible job passable, tho there is still some confusion. Ford also began showing decent pictures to go along with the codes.
Basic Ford part number for a stripe kit in the TAPE section: 20000
Old Feb 1, 2007 | 03:52 PM
NumberDummy
At the beginning in 1980, Ford listed it as both AOD and AOT in the parts books.
