Battery Question
Old Feb 1, 2007 | 09:03 AM
taisa899's Avatar
taisa899
Battery Question
would a dead cell in a battery cause you to get a reading of 14.5V off of it. That reading is with the truck not running
Jim
Old Feb 1, 2007 | 02:17 PM
SPL Tech's Avatar
SPL Tech
No if one of the cells is dead the voltage would read lower then normal. The reason why the battery reads that high is because either the truck was just running and you took a measurement and you are reading the floating voltage and/ or the battery is cold. Cold batteries have higher floating voltages. If you want to take a true measurement let the vehicle sit in a warm garage for two hours then read it.
Dont worry about that reading. It does not indicate anything is wrong.
Old Feb 1, 2007 | 02:28 PM
taisa899's Avatar
taisa899
well i replaced the battery anyways. but now I just started the truck and let it run for a while with the alternator removed and the voltage in the battery just keeps climbing. Now it's up to 19.4V
Jim
Old Feb 1, 2007 | 03:11 PM
merlynr's Avatar
merlynr
test your voltmeter on another battery. Could be a faulty reading.
Old Feb 1, 2007 | 05:09 PM
Franklin2's Avatar
Franklin2
Do not run the truck with the alternator disconnected. It is possible to ruin the electronics. With everything connected, and the truck at idle, you should have around 14.5 volts on the battery.
Take the reading this way, and see what you get. That will give you a better health report on your charging system.
Old Feb 1, 2007 | 11:57 PM
SPL Tech's Avatar
SPL Tech
Jim
Its not physically possible for a 12 volt battery to reach that high of a voltage without an alternator or other charging device. So get a different multimeter and try. Your metering the batteries voltage not the alternators when you had the alternator disconnected right? Regardless of a batteries state the voltage cannot increase much beyond 12.6 volts without any charge on it and with no floating voltage on it. Its a matter of physics. The cells in a 12 volt lead acid battery are about 2.1 volts each fully charged. The battery has six of them. With all six you get 12.6 volts. A damaged or defective battery can will show abnormally low voltage but it cannot show abnormally high voltage.
