Where Can I Find
Old Feb 1, 2007 | 03:43 AM
JZTRK's Avatar
JZTRK
Where Can I Find
I Bought A Running 460 Out Of A 85 F250 4x4 Manual Trans For My 76 F350 2wd Auto Trans To Make It Work I Only Had To Change The Flywheel Dose Any Body Know What The Differance Is Between The 76 Engine And The 85is ? I'm Ready To Rebuild It Now But I Dont Know What The 85 460 Is Where Can I Find Some Casting ###
The Down Side Is That The 76 Motor Had One Hell Of A Knock So I Gave It Up For A Core Exchange
ALSO IF IT HELPS THE HARMONIC BALANCER IS ABOUT 1/2 THE SIZE ON THE 85 MOTOR
Old Feb 1, 2007 | 04:11 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Exclamation 460 Flywheels 1973/89
460 Flywheels with A/T 1973/89
D1SZ-6375-A ALL with unweighted (D00Z-6359-A) spacer 1973/79; EXCEPT: 1978/9 using weighted (D9TZ-6359-A) spacer.
D9TZ-6375-A Use with weighted spacer 1978/79 (use w/short block D8AZ-6009-A)
D9TZ-6375-A ALL 1980/89
(I have no knowledge about engine swaps)
Old Feb 1, 2007 | 05:50 PM
RTM's Avatar
RTM
79 and up motors are externaly balanced and 78 and older are internnal.
