Modular V10 (6.8l)
rough idle ... checked everything what can it be?
Old Jan 31, 2007 | 05:21 PM
chuck641's Avatar
chuck641
My '99 V-10 has been idling horribly for the last couple weeks. My check engine light has been on .. the codes are P0171 and P0174, both say "system too lean". I posted all the symptoms and everyone recommended getting a new IAC. I first cleaned the old one, unplugged the battery, put everything back together ... the check engine light went off but the truck still ran like crap. So I got a new IAC, put it on and the check engine light is back off after unplugging the battery but the truck is still running like crap. I have made sure all the vac hoses are connected, made sure all the electrical connections are together, and cleaned the MAF sensor. I also put a brand new air filter, pcv valve, and fuel filter on it.
Does anyone know what is next? new O2 sensors? new MAF sensor? this thing is driving me nuts.
Thanks, Jason
Old Jan 31, 2007 | 11:04 PM
FortyFords's Avatar
FortyFords
You chkd the hose that goes to the pcv valve ? There is a elbow in that hose that likes to split and cause a vacum leak .
Also in 99 there were case where the intake gasket o-rings leaked and caused a vacum leak .
What you have is un-metered air entering the system causing a lean condition .
most of the time.
Then there is a condition where yor running rich and the pcm tries to compensate by adjusting fuel trims to most oposite (lean)
This is the downfall of OBDII ssystem.
But yours sounds like a vacum leak.
Don't forget the hose going to the brake booster also
Rich
Old Feb 1, 2007 | 09:06 AM
Big Orn's Avatar
Big Orn
Could be the EGR valve, too.
Also, something to look at - is the battery good? It might just crank the truck, but if it's going south it could cause some problems like that. Simple but...well, you know.
Old Feb 1, 2007 | 10:31 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
You have to read the codes... the check engine light was on, which it usually isn't for an IAC or MAF...
Old Feb 1, 2007 | 10:34 AM
chuck641's Avatar
chuck641
Battery was brand new a couple months ago.
I did read the codes and they are both O2 sensor codes, I highly doubt both O2 sensors went at once, they are just both reading a lean condition.
I will check the PCV and brake booster hose again when I get home tonight. I am pretty sure they are both good but I may have missed something. Come to think of it, I remember wiping some grease/oil off the PCV hose, I wonder if that had been covering up a crack I didn't notice. That is probably where that grease came from.
Old Feb 1, 2007 | 11:07 AM
Keith Smith's Avatar
Keith Smith
Does the truck run better once it warms up? If so, it is likely the intake manifold gaskets leaking. That was what was going on with my son's explorer. It has a plastic intake manifold. As the weather got colder, the worse it ran because the thermal expansion was taking longer to seal up the leaking gaskets. A cracked intake manifold will do the same thing. If the crack or leak is bad enough, it may not seal itself as the engine warms.
Old Feb 1, 2007 | 02:30 PM
krewat's Avatar
krewat
The V10 has a cast aluminum intake on the 2-valve. The 3-valve is a plastic intake. The original poster's V10 is a 2-valve.
Old Feb 1, 2007 | 04:38 PM
chuck641's Avatar
chuck641
PROBLEM FIXED!! Thank you FORTYFORDS and everyone else for your ideas.
It ended up being the hose that goes to the PCV valve, it was cracked in 3 spots right below the throttle body where it has a tight bend in the hose ... which happens to be right where I wiped up the oil from, I can't believe I didn't notice the cracks at that point. Anyway, I slipped on a new chunk of 5/8" rubber hose and she is runnin better than ever.
Thanks again, Jason
Old Feb 1, 2007 | 05:00 PM
Big Orn's Avatar
Big Orn
Chuck - get that OEM elbow when you get a chance. On some engines, just a regular hose will fail with all the rubbing going on in there.
Sometimes you have to buy the entire hose assembly, but surely a parts house has just the elbow...
OBTW - good for Old Forty - the old fart needs kudos now and them to keep his pumper going....
Old Feb 1, 2007 | 05:34 PM
krewat's Avatar
krewat
Rich strikes again!
The dreaded PCV elbow...
Old Feb 1, 2007 | 06:00 PM
chuck641's Avatar
chuck641
I will get the right one when I get a chance, but I had the piece of hose so I just used it. The piece I used is about a foot long and I routed it out and around the throttle linkage then attached it to that smaller hose so I wouldn't have that sharp bend in a hose that wasn't meant for it. Thank you all.
Jason
Old Feb 2, 2007 | 08:23 AM
FortyFords's Avatar
FortyFords
Thanks again, Jason
Your welcome!
Rich
