1978 - 1996 Big Bronco
electric shift problem
Old Jan 31, 2007 | 04:29 PM
Don P.'s Avatar
Don P.
Hi all. I just got a 94 bronco with push button 4x4. It wasn't working when I got it, and I happened to have a new motor for an 89 bronco, so I swaped it. Now it will shift to 4 hi normaly, but sometimes it will kick itself into nuetral while driving. Usually after I let off the gas. I have to stop and shut off the motor to shift back to 2 wheel drive without grinding. Any ideas or info would be appreciated. Thanks; Don
Old Feb 1, 2007 | 07:43 AM
alxsnmr's Avatar
alxsnmr
4Hi is on the same cam as the HI and Low range reduction. You might crawl under the truck and see if there is play on the shaft but I doubt you will be able to tell very much from outside the transfer case. Basically, you could have a cam problem, range reduction fork, or even the planetary gear set is worn badly. You can not tell what it is with out taking the transfer case out and disassembling it.
S-10 warrior
Sep 17, 2016 08:05 PM
Ford Guy 72
Feb 17, 2014 10:53 PM
DaveCinIN
Apr 21, 2013 09:38 PM
wild4wd
Jun 20, 2003 11:17 PM
1rocket
Nov 22, 2002 05:26 PM
