Here's your sign......
Old Jan 30, 2007 | 02:35 PM
BowTieHatr's Avatar
BowTieHatr
ok this morning, a local customer brought his truck to us for a oil leak and we were talking about his truck. we put a couple of injectors in it for a no power, skipping when cold last week and he states it is still doing it. i told informed him why the injectors were sticking and why the temp being low makes it worse. then he looks at me and grins. he finnaly tells me he is running a oil additve "treatment". needless to say we changed his oil before he left and i dont expect to see him back with a cold start issue for a while.
Old Jan 30, 2007 | 03:17 PM
Lonewolftx's Avatar
Lonewolftx
Talking Yeah, Yippee . . . .
Aren't you having a GREAT DAY IN THE NEIGHBORHOOD!!!!
Old Jan 30, 2007 | 03:53 PM
firesoutmatt's Avatar
firesoutmatt
sign
Gotta luv them . Wonder how many trucks would have gotten fixed the first time if the owners were honest...................
Heres your sign .
Old Jan 30, 2007 | 03:59 PM
WilliesSD250's Avatar
WilliesSD250
Well it goes with that old addage....."If your gonna play, you gotta be willing to pay" Like most diesel owners I'm aware of the cost of repairs and I will be more than honest with the service department if something on my truck breaks or doesn't work due to something I did.
But I'm sure there's lot's of Tech's and service advisors out there that have had that customer tell them "yea It's doing such and such and I don't know why", but you know they know "why"
Old Jan 30, 2007 | 04:03 PM
Bob Ayers's Avatar
Bob Ayers
Interesting! And what was causing the oil leak?
Old Jan 30, 2007 | 09:34 PM
npccpartsman's Avatar
npccpartsman
LMAO--your day sounds like my day BTH. Oil additives and 100k bypassed oil changes...holy smoke... and people say fords ain't tough??? PLEASE!!!
Old Jan 31, 2007 | 11:10 PM
exiled's Avatar
exiled
BowTieHatr, why the sigh? Is it because he used the treatment or cause he did'nt mention it? Only reason i ask is because untell last friday i did'nt know that the oiltreatment could stop the truck from running or mess with the performace. I just luckly ask a buddy of mine if he ever uses oiltreatment in his. He's brother is a diesel mechanic{sadly he doesnt work for ford} and he had told him that the treatment was hurting the 6.0's but most times changing the oil and filters fixed it.
i know the owner manuakls says you should'nt have to use oil treatment but it also says you should'nt need to use fuel treatment other than for an anti-gel.
I hope this does'nt sound harsh, cause i dont mean it that way at all, i was suprised that a treatment could cause such mahem.
Old Feb 1, 2007 | 04:39 AM
npccpartsman
It's what the treatments do to the injector spool valves. Most oil treatments that have additives that "stop oil burning" do so by plugging up the tiny wear marks in the cylinder walls and round the rings. We used to call it varnish in the 60's. I'm not sure what you would call it now--probably gunk . At any rate--it causes the spool valves in the injectors to stick which causes misfires and is exactly what the latest flash is supposed to prevent. I may be totally off base here, but that's my thinking on it. Good oil and regular changes make these oil treatments (which are bandaids at best anyway) unnecessary. If you have a motor problem that large you should probably have it overhauled anyway.
Old Feb 1, 2007 | 07:11 AM
BowTieHatr's Avatar
BowTieHatr
tim, we are thinking on the same page.
Old Feb 1, 2007 | 09:10 AM
exiled's Avatar
exiled
I'm sorta on the same page guys. I just to know why the sign. I can see the sign on keeping the fact from the service tech that you used the treatment. But then again i could see if you did'nt know the treatment would hurt it that the person would'nt think to tell the service department they used it unless someone asked. I use lucas in my gas burners and i really dont think about about it much. Its so common place for me. I know 2 7.3 owners that uses lucas and a few brand x's and they dont have issues. I think a sign is alittle harsh on someone just because they used oiltreatment unless its a repeated thing.
Old Feb 1, 2007 | 09:54 AM
BowTieHatr's Avatar
BowTieHatr
its was meant to be a joke exiled, relax.
Old Feb 1, 2007 | 03:56 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
None of these have the very low tolerance, spool-fired injectors of the 6.0.
Old Feb 1, 2007 | 07:40 PM
WWMike's Avatar
WWMike
One thing people don't understand. The reflash from international is meant to flow oil through the injector after shut off to take heat away during the natural "heat soak" that takes place after shut off. This heat soak causes the oil to oxidize in the injectors especially if the oil hasn't been changed on time. An oil flush product added to the old oil followed by an oil change and the reflash will repair the cold start problem.
Old Feb 2, 2007 | 05:16 AM
npccpartsman
There isn't any way to flow oil to the injectors with the motor shutoff. Oil to the injectors is supplied by the high pressure oil pump which is gear driven from the cam/crank. The reflash is meant to empty oil from the injectors, not flush oil through them. I'd be interested to know what source of information provided your theory. Can you supply any written documentation to prove it?
Old Feb 2, 2007 | 05:32 AM
WWMike's Avatar
WWMike
This info was from an International engineer. He told me that the engine was equiped with an accumulator to store and balance the oil pressure from the high pressure pump. This after run cycle doesn't empty the injector, it just keeps the traped oil in the injector from oxidizing due to heat soak. It doesn't make sense that the oil could be drained, yet the vehicle would restart. If the injector was emptied of oil it would be full of air and we all know what air in the high pressure system does. He was very frustrated because the Ford Motor Company people could not grasp this.
