84 f150 fusible link
Old Jan 30, 2007 | 11:42 AM
POS91CivicHb's Avatar
POS91CivicHb
Just signed up for the forum. I just picked up an 84 F150 for cheap and it ran and drive, but after I let it sit a couple of days it won't start. I checked the battery connections and they seem fine. Then I checked the grounds and they were pretty bad so I cleaned them up and still no juice. I'm thinking it might be fusible link I found one that seems to have burnt up. My question is what is the best way to replace the link? Should I just use the same gauge wire? Should I put a fuse in line? Any help is appreciated I need to get the truck running asap.
Old Jan 30, 2007 | 12:02 PM
f100jim's Avatar
f100jim
Do not replace it with the same gauge wire. If there is a short, it may destroy your wiring, or it may even start a fire. Why not replace the fusible link with a new fusible link? I bought a couple of packages of fusible link at the local auto parts store for a few bucks.
Old Jan 30, 2007 | 12:03 PM
SCRWDRVR's Avatar
SCRWDRVR
"Obsessed"
The best way to change the link is just cut it out and put a new one in. That sounds a awful lot like a bad battery though. Will it jump start after it sits?
Old Jan 30, 2007 | 12:06 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
You need to replace the Fuse link with the same exact gauge fuse link.
These are avaliable at most auto parts stores.
The grounding problem could have caused the link to blow, but be prepared for the new one to also blow, and if it does, then you will need to find the wiring problem.
It wouldnt hurt to inspect all the wiring just to be safe anyhow. Check it for rubs cuts, funny marks etc...
hope this helps...
Old Jan 30, 2007 | 12:14 PM
POS91CivicHb
THere is so many cut wires in this truck. I tried to jump it, but it wouldn't even turn over and still didn't get any juice.
Old Jan 30, 2007 | 12:34 PM
81-F-150-Explorer
Fix all the wiring you can find problems with. If the harness is severely hacked up, it might be prudent to replace the main harness.
This could also be the reason, (and the most likely) why the fuse link blew.
ShaneNP123
17
Mar 28, 2015 07:59 PM
Island Time
Electrical Systems/Wiring
Jul 6, 2014 07:26 PM
Onus
Oct 1, 2011 09:36 AM
'77fordtony
May 6, 2005 10:23 PM
punksb
Oct 7, 2000 12:52 PM
