All you have to do is get the axles. You could probably get a new set drilled for 8-lug from Moser, Strange, Superior, etc. for somewhere around $250-300
I don't think there's enough of an axle flange dia. to drill for the 8 lugs. Measure the dia. and see what you get. Keep in mind the 8 ug pattern has a BC od 6.5.
my old 77 has 205 np with constant vol drive line, threaded yoke.
swap to a u-bolt yoke, a cross at each end .
anyone got a # for the seal ? 50 miles to parts store
thanks paducah
