General Automotive Discussion
Cold weather warm up
Old Jan 30, 2007 | 05:07 AM
fredbuilt's Avatar
fredbuilt
How people actually warm up there vehicle before the use it? Asoon as the temps start to get below 50 I warm it up about 5 to 10 minutes. Anything below freezing I let it warm up about 20 to 30 minutes. Days that it is below 30 to 40 minutes, or call in sick LOL
Old Jan 30, 2007 | 06:56 AM
modar's Avatar
modar
I just start and go. The engine will warm up faster when you're driving. The tranny stays cold if you're parked and just idling the motor. if it's really bad outside and there is thick ice on the windshield I let her idle while scraping the glass off. I picked up something call "HOT ENERGY windshield DE-ICER at walmart the other day, it says it will remove ice fast with no harm to vehicle's finish......lol, it turns the ice red, thats all, no melting, just coloring. stay away from this product.
Old Jan 30, 2007 | 07:14 AM
94van's Avatar
94van
Wow, you sure seem to waste a lot of gas with those long warm-ups.
I start and go after about 30 seconds in cold weather, and drive slow for about the first mile.
Old Jan 30, 2007 | 07:24 AM
jroehl's Avatar
jroehl
I'm with modar--get in and go. Or, start it, scrape, then go. Five minutes of driving, and the ol' truck is pretty much up to temp. Idling just wastes gas. Today's vehicles start wasting gas after about 30 seconds to a minute of idling. In other words, they use less gas if you shut them off when you're going to be sitting for more than a minute.
Jason
Old Jan 30, 2007 | 07:52 AM
john112deere's Avatar
john112deere
I usually give it 15 seconds or so (clutch out, in neutral) regardless of weather, and maybe a minute or so if it's below around 20 degrees. But if she sits for a while, or it's real cold, or worst, sits when it's real cold, the valves make their displeasure known when I first fire it up. Warm-up for a minute or so after they shut up.
I also try to really baby it until the temp gauge starts to move, and try not get on the highway or heavy on the throttle until it's up to temp.
Old Jan 30, 2007 | 08:04 AM
Mr Incredible's Avatar
Mr Incredible
The only time I let it warm up more than 30 seconds is when there's ice on the glass that needs heat to clear. Drive easy and let it warm up over a few miles.
It was 0* here this morning. I get a warm motor within three miles. Tranny takes a bit longer.
Old Jan 30, 2007 | 01:01 PM
Steina's Avatar
Steina
CO River Rat
On modern vehicles, that much idling will do a job on the cats.
Steve
Old Jan 30, 2007 | 02:33 PM
FarmForward's Avatar
FarmForward
I tend to just start up and head out. Maybe if it's REAL cold I'll sit for a minute to let the valves stop chattering, but that's about it. I park inside a shed, so ice on the windshield is'nt generally a problem. Both my F150 and the Bronco tend to warm up pretty quickly.
Old Jan 30, 2007 | 02:42 PM
pitrow's Avatar
pitrow
I second everyone else out here. Letting it sit idling is just plain a bad idea.
Around here it's usually pretty frosty in the mornings so I fire it up, turn the defrost (front and rear) on and then scrape the windows. Then since the windows have a tendency to get really foggy unless they have a little heat on them, I rev it up to about 2k for about a minute, maybe two. Just enough that I see the temp needle start to move. I know that's not the best on it either, but it sure beats running off the road cause I can't see where I'm going. Then I'm on the road and going. I'm usually up to full temperature before the end of my gravel road.
Old Jan 30, 2007 | 02:50 PM
CA55F100's Avatar
CA55F100
Since I have a baby, I put a small space heater (with Safety guards built in) into the van for 30 minutes prior to leaving. THis takes the edge off of the 0 degree temps.
As for the truck, I tend to idle about 3-5 minutes to burn through the frost. Some days less, some days more.
The truck sits outside.
Old Jan 30, 2007 | 03:05 PM
fl1a's Avatar
fl1a
I let mine idle until the engine idles down, usually about 5 minutes. The defroster
begins to work by then too.
Old Jan 30, 2007 | 03:17 PM
CougarXR02's Avatar
CougarXR02
Thats what I tend to do more often then not. In the bitter cold i just start it and let it sit for 10-20 minutes, whenever I get around to leaving.
I am curious if anyone knows what exactly idling is supposed to do to the cats? I have heard this from manufacturers and other sources, Yet I can't seem to think of the science behind it. Am I missing something?
Old Jan 30, 2007 | 04:49 PM
jroehl's Avatar
jroehl
At start-up, the computer directs the engine to run richer than normal because everything is cold, when the gas doesn't vaporize as readily. So, to get an adequate flame in the cylinder, more fuel is dumped in, which doesn't necessarily burn. Fuel that isn't fully burned is what causes carbon deposits on everything inside an engine (oil can do it, too), including the cats, eventually clogging them.
Jason
Old Jan 30, 2007 | 05:21 PM
Steina's Avatar
Steina
CO River Rat
Carbon isn't what ruins cats; raw fuel during a long warm-up period causes them to overheat, destroying the precious metals inside. Some Owner's Guides have a warning about prolonged idling over anything combustible, like dry grass.
Steve
lariat97's Avatar
lariat97
I let my van run long enough to clear the windshield then I hit the road. Probably 5 minutes tops
