1978 - 1996 Big Bronco
Limited Slip Diff
Old Jan 9, 2003 | 10:34 PM
bronco cam's Avatar
bronco cam
Limited Slip Diff
Steve I just saw a replacement clutch pack for sale for the ford limited slip. The person stated that with there clutch pack it will make a ford limited slip clutches stronger,they will last longer and engage easier have you heard of anything like this?
Old Jan 10, 2003 | 06:03 PM
fors43's Avatar
fors43
Limited Slip Diff
SO to be clear Steve, on a '95 Bronco with a rear LS, how can you tell if the front diff. is LS?
Old Jan 12, 2003 | 02:08 AM
steve83's Avatar
steve83
Limited Slip Diff
[updated:LAST EDITED ON 01-12-03 AT 03:10 AM (EST)]>pack it will make a ford limited slip clutches stronger,they
>anything like this?
They're blowing smoke. The only way their kit could make it "stronger" is if they're thicker or there are more clutches, causing more spring pressure, but ANY new kit would do that, too. And if there's more pressure, they DEFINITELY won't last longer because there'll be more wear, and they're ALWAYS "engaged" so that's bs also.
fors43
Lock both hubs (with auto hubs don't worry), lift ONE tire, and spin it until both hubs have locked in. If the only drag you feel is from the driveshaft spinning, it's open or your L/S is worn out. If your L/S is working, you'll barely be able to spin the wheel by hand. Alternatively, look at the sticker on the front axle, but I've never seen a '92-96 L/S so I don't know what to tell you to look for. Got a digital camera?
Old Jan 12, 2003 | 02:11 AM
steve83's Avatar
steve83
Limited Slip Diff
Pappawheely
Jan 29, 2016 11:53 AM
jeffbradbury7
1983 - 2012 Ranger & B-Series
Jan 12, 2016 07:05 PM
ctroyp
Jan 22, 2014 10:28 AM
Matt03Expy
Dec 18, 2005 11:54 AM
cwb
Offroad & 4x4
Jul 15, 2003 12:27 PM
