tach problems
Old Jan 29, 2007 | 07:20 PM
u.f.o's Avatar
u.f.o
tach problems
My tach quits sometimes when i slow down or stop. Is that the sensor? If so where is it located. 92 7.3
Old Jan 29, 2007 | 08:05 PM
davelong667's Avatar
davelong667
Smile
The sensor is located right next to the place where you fill your engine with oil, the oil fill neck. It is a 1" nut with 2 wires coming out of it. I know because I am currently in need of a new one. I think that I read from cheeperjeeper, that is a Dealer ONLY item. You cant just jot down to the local auto parts store and get one. That is probably your problem, the sensor.
Old Jan 30, 2007 | 05:48 AM
u.f.o's Avatar
u.f.o
Thanks, davelong667 I will try that. u.f.o.
Old Jan 31, 2007 | 07:39 AM
PLC7.3's Avatar
PLC7.3
Do check for wires close to the nut, mine had a tendancy to touch due to the wire shielding pulling back out of the nut/silicone. Fan air velocity had an effect as to whether the wires touched or not.
