Sponsored by: Real Truck
Another tire question
Old Jan 29, 2007 | 06:57 PM
65983cobra's Avatar
65983cobra
2006 F 250 crew cab. What is the tallest tire i can run on stock hight.
Old Jan 29, 2007 | 06:59 PM
ECA's Avatar
ECA
4x4? Should be a 295/65R16. BF Goods are sweet.
Old Jan 29, 2007 | 07:22 PM
f250meangreen's Avatar
f250meangreen
My buddy has a 05 with the 18" rims, Continental tires. Replaced them with 305/65R18 BFG AT and still plenty of room. The problem is getting the E load when you get bigger. If D load is good enough you can go bigger. 325/65R18 would probably look great but it is a D load. Good luck, I am starting my search now. I won't need tires until next winter but it is hard to find E load in larger sizes.
Old Jan 29, 2007 | 11:17 PM
RJB1's Avatar
RJB1
I am running the 305 65 18s on my 05 SD, they fix good with no rubbing...
Old Jan 30, 2007 | 05:22 AM
jim6090's Avatar
jim6090
325s with stock 17"rims??? Have you tried it?? I am currently running 285-70-17s. The 285s appear to be about as wide a tire you want on the stock rim.
Thoughts?
Old Jan 30, 2007 | 05:40 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Moved to Sd.
