Oil pressure woes #2
Old 01-29-2007, 05:54 PM
cfrives3's Avatar
cfrives3
cfrives3 is offline
Just to let you guys know, I fired up the old motor today-it's only in the thirties today here. Oil pressure went to about 30 lbs for about 30 seconds then fell to about 5 lbs, way before the fast idle solenoid kicked her down to normal idle. Any way, since it had a few lbs., I moved a couple of my other trucks around and came back after it had kicked down and idled for a couple of minutes. I played with the throttle to see if I could get the oil pressure needle to move, at best, I got it to jiggle. I'm thinking that putting an oil pump in it first would be the best way to go, seeing as how I've no idea how many miles are on the motor, an oil pump at this point would be an insurance policy. If this doesn't do it, then I guess I'll check out the cam bearings. If that doesn't do it, well, I guess I'll be on here crying to you guys! Ha! Ha! Ha!
Old 01-30-2007, 12:16 AM
PLC7.3's Avatar
PLC7.3
PLC7.3 is offline
What oil are you using and what filter...... is this an aftermarket manual oil guage or one of fords better ideas/rejects.
Old 01-30-2007, 09:09 AM
cfrives3's Avatar
cfrives3
cfrives3 is offline
see oil pressure woes- the first one, not this one, for the whole story.
Old 01-31-2007, 07:47 AM
PLC7.3's Avatar
PLC7.3
PLC7.3 is offline
You would get better continuity if you posted back to the original post........
Old 01-31-2007, 11:03 AM
cfrives3's Avatar
cfrives3
cfrives3 is offline
10-4 will do.
