300-6 performance
Old Jan 29, 2007 | 12:19 PM
95Ford4x4's Avatar
95Ford4x4
what about air intake systems like air raid and k&n?? i've never seen one advertised to fit the 300. is there one for these motors??
Old Jan 29, 2007 | 05:25 PM
ReAX's Avatar
ReAX
I had one that fit the two tube intake. It made a noticable difference, However, it is just a cone filter with two outlets and two brackets. I spent an hour in ACE and made the tubes to finish it off.
Old Feb 1, 2007 | 12:25 AM
scottfreeman's Avatar
scottfreeman
They aren't that complicated, build one. save yourself around a $150 dollars. I built one for my wife's '99 Explorer. I built a box out of aluminum for the rice-eater cone filter to sit in and bolted the filter to the MAF sensor, sounds way cool. I want to build the pipe that goes inbetween the MAF and the throttlebody next, just need time.
Old Feb 1, 2007 | 10:32 AM
inline6 Red Neck's Avatar
inline6 Red Neck
for mine i went to autozone and bought two cone filters and a 6" extenstion tube so i could run my pvc hose into it and so the filters wouldn't be right next to each other then i made abraket to hold them up and secure cost about $55.00 mine was $35.00 because i had a gift card
Old Feb 1, 2007 | 10:56 AM
300I6VAN85's Avatar
300I6VAN85
I also had to fab my own adapter for one big K&N filter to fit the Holley390 that sits on the Clifford manifold in my van. I rolled some flat stock steel, welded a top to to and rolled another neck that faces the front of the van which the K&N is connected. And yes it does sound way cool at full honk boogie. I want to make a shroud to protect the filter, but it is working good. It's been on there for a year. Oh! By the way: K&N makes a good product and has been around for a long time.
Old Feb 1, 2007 | 02:18 PM
Silver Streak's Avatar
Silver Streak
Do a search and you will find a ton of info on this topic.
Old Feb 2, 2007 | 07:47 AM
SR_Crewchief's Avatar
SR_Crewchief
For our naturally aspirated EFI's the FIPK's a overpriced for the results. Unless you done something to dramaticly increase the airflow demand the stock airbox more than adiquate.
The only real issue is with the paper elements commonly used, they are a segnificant flow restriction. Replace that with a high flow replacement element (example Fram AirHog, K&N direct replacement, etc) and you'll have the airflow delivery you need for most EFI 300 performance changes.
Old Feb 2, 2007 | 10:38 AM
Silver Streak
The stock filter is not a restriction until you've got significant mods done. The difference between a nasty filter with caked on crud (which I am embarrassed to have found on my truck) and no filter at all was only 2 hp. A clean paper filter will fall somewhere in between.
Old Feb 10, 2007 | 08:09 PM
KAS300's Avatar
KAS300
Unless you have a MAS air equipped motor, they wont make a difference.
Same goes for drop in K&N's.
Old Feb 11, 2007 | 12:42 AM
89300L64x4's Avatar
89300L64x4
anyone try the air raid thottle body spacer? ive also heard of porting the intake for a bbk 302 performance thottle body
Old Feb 11, 2007 | 01:58 PM
KAS300's Avatar
KAS300
The 4.9L already has an exceptionally long intake tract. Adding another 1/2" isn't going to make a difference.
Same goes for a bigger throttle body. Putting a bigger TB on the same intake manifold wont do anything.
Old Feb 11, 2007 | 09:52 PM
scottfreeman
Exhaust makes the biggest difference. Go with full length headers and some big diameter pipes and free flowing mufflers and you will notice a difference. Also, have the curve on the distributer tuned for the mods, makes the difference, worth the $$$$. Get the head ported, factory set-up is stupid restrictive.
Old Feb 12, 2007 | 08:19 AM
89300L64x4's Avatar
89300L64x4
i figure if you have a performance cam,exhaust,chip,and ignition; a bigger tb and spacer plus intake will help it produce more power cause of the bigger demand of air the motor would want.
Old Feb 12, 2007 | 10:58 AM
SR_Crewchief
The only problem with that is that intake and TB aren't airflow restrictions until higher RPM's. The big airflow restriction is the head itself. The EFI head can only handle a mild port before you punch through in the the AIR journals (Intake port?).
The off the self "chips" only play with the ignition timing which is why they all recomend higher octane when in use.
The single biggest hinderance to performance gains in the EFI 300 is the lack commonly available custom tuning support for the stock EEC-IV's.
Old Feb 13, 2007 | 01:16 AM
89300L64x4's Avatar
89300L64x4
yeah it would be nice if somone made a engine mangement box for a laptop or somthin. btw TS performance does make a chip with a switch on the fly for 87 and 93 octane levels i wish it sed how much it cost but it dont
http://www.tsperformance.com/gas-tuning.html
