How far is too far? A bit of a rant.
How far is too far?
I suppose this is a question most of you have asked yourselves at least once when staring at a new project. How far do I go with this? I am right in the middle of this very evaluation as I had my new 66 on the lift for the first time and I was able to really poke around in the hard to get to places and see the true shape of the truck. Needless to say I found rust and decay that I hadn’t seen before (I discovered the radiator support is completely gone underneath the radiator which has allowed it to drop .5” on the passengers side and now there is a small leak in the rad). In the last few days I had just ordered new hoses and belts, a few replacement body panels including the lower door pillars and floor pans, new tires and new kingpin kits and front end bushings. I bought this truck to use it not because I needed another project. I’m generally not an **** guy so I don’t need things to be perfect all the time, but I am a machinist so I tend to do things the way I know them to be right. I general don’t use JB weld when I can replace a part with a new one if you know what I mean. So looking at this truck today my first instinct was that I needed to take the cab and the bed off the frame, sand blast everything weld in repair panels where the body is rusted through replace bushings and bolts etc. etc.. I have a fairly conservative budget for this truck which I am fast approaching the limit of. Luckily I also have a number of years in the auto body and mechanics field so I can do most of the labor myself. The thing that I am most concerned about is: the fact that with some places are already rusted through, and that living in there is a real possibility of salt and snow on the roads (especially this time of year). I want to do enough to the truck to not have to worry about it rotting away to the point of junk, but can’t get into a full restoration project. I don’t like the idea of using por-15 to cover what should be replaced, but I guess I’m going to have to compromise and fix the things I can, accept the things that I cannot, and hope that I can tell the difference.
Lug Nut; sounds like you just about answer your own question. I would also suggest, initial repairs to areas of most important's like cab mounts, rad support it able. you could get it mechanically & driveablilty right than cosmetic's later. The rad support repair seems to be the hardest area. cab mounts & floor boards are a weekend repair if you got the facilities and tools.
The questions is; What level of recondition are you looking at. Daily driver; total body off resto Show & Go etc?
Mitch
Mitch
on
Lug Nut! I looked at the pictures you posted and honestly thought "this guy needs a new cab". But since you are a mechanic and seem to have a solid idea of what needs to be done to repair the cab, I recommend you continue the project. Both OEM and aftermarket core supports are available (not cheap) but they are available. Most everything else can be patched or replaced. Good luck!
I struggled with this throughout my whole project as well.
The truck was a total Flintstone mobile when I got it, and it was much worse than I'd ever imagined. I kept plugging away at it, knowing that there was no way to do a total body-off show quality job - it was just too far gone. I replaced a lot of metal (cab mounts, floors, cab corners, bed corners, fenders) and had to repair the core support.
In the end I ended up with a nice looking, usable truck, that I can haul things with, and launch my boat, but I don't have to worry if someone scratches it in a parking lot. It's not perfect, and a vintage car expert would probably cringe, but I'm happy with the result. Do what you need to make it safe to drive if you want to use it as a truck. Anything else you can afford is just extra.
