1978 - 1996 Big Bronco
alternators
Old Jan 11, 2003 | 08:09 AM
square head's Avatar
square head
alternators
[updated:LAST EDITED ON 01-11-03 AT 09:36 AM (EST)] on my 82 bronco i only have 2 wires going to my alternator,but there are 3 places for wires,i've hook up the positive wire and the other one and have grounded it to the frame,whats the one stud sticking out marked " S "?i have a brand new batterry,starter relay, and electrinic regultor, and the alternator is new,it's not charging my battery. HELP!
Old Jan 11, 2003 | 09:23 AM
Johnny88Bronco's Avatar
Johnny88Bronco
alternators
Not likely but could be a DOA alternator. Have a parts store test your alternator, they do it for free. Also have them test your battery, could be you have a bad battery, not common but i've also seen DOA batteries that were prob dropped or mistreated during shipping.
After that, i'd double check to make sure all of your wiring was put back where it was supposed to go.
Good Luck
Old Jan 11, 2003 | 10:51 AM
square head
alternators
battery and alternator checked,both good.does the electrinic regulator need to be grounded?
Old Jan 12, 2003 | 12:00 AM
greystreak92's Avatar
greystreak92
alternators
Yes, if you have an external voltage regulator, it should have a negative/ground wire from one terminal.
Old Jan 12, 2003 | 06:47 PM
screwy's Avatar
screwy
alternators
Old Jan 13, 2003 | 07:37 PM
square head
alternators
ok ,on my alternator there is a connector marked S, no wire is one it,is one suppose to go there?if so where would it go to?also on my electrinic regulator i have to wires coming from the place marked A,one wire goes somewhere the other is yellow and is cut,where does that go?
