who knows this answer
Old Jan 28, 2007 | 11:14 PM
bigtorque's Avatar
bigtorque
ok, how to get better flow from an old 2 valve per cylinder diesel head,
does any one know the intake and exhaust valve size,
any one ever port and polished the heads.
and moved up in valve sizes, this is mostly just wishful thinking on my part as an inquirey.
Old Jan 28, 2007 | 11:41 PM
Tenn01PSD350's Avatar
Tenn01PSD350
I hear you bro. I've thought about this too ala old school porting stuff.
Unfortunately, what I have found thus far is that the setup does not leave too much to be desired, even in the camshaft department. I do not know if this is because IH designed it that well or because the total sum of the parts will not net an appreciable gain. It is a turbocharged engine so flow says only real big problem corrections net big gains.
I do know polishing and porting has never hurt unless you botch it and gains can be had. Just don't think I'm gonna do it but glad you asked because if somone can say that it is a big improvement, I will do it. Also, I believe we have regular hydraulic lifters. I have heard nothing of roller solids or hydraulics in these. Wonder why? Probably nobody makes them. Seems everything with the 7.3 is a bolt on.
Old Jan 29, 2007 | 07:49 AM
Pocket's Avatar
Pocket
Tenn is right. There hasn't been much luck in the porting department, or cams for that matter. The high HP 7.3's out there seem to be doing better with only very light head work and valve spring replacment. Other than that, not much else is going on up there. There's been a few who have played around with custom grind cams and that has actually caused a loss of power.
Old Jan 29, 2007 | 09:17 AM
roaky81's Avatar
roaky81
Just food for thought on polishing the intake runners on normally aspirated carburated motors. An old motorhead told me that it's not a good idea on daily drivers, just on Hi-perf motors that you want to keep the revs up. The rough sides help swirl the air/fuel mixture together during low RPM's to provide a better burn pattern in the cylinder. Now on turbo/injector motors, I don't see a lot of gain from doing porting or polishing unless there's a huge mismatch in the pathway.
Old Jan 29, 2007 | 09:40 AM
Kwikkordead's Avatar
Kwikkordead
Seems like it's best to leave it all alone going on what Pocket has stated.
Also the PSD from the factory is fitted with roller hydraulic self-adjusting lifters.
