questions on bilding an inline six
the truck is a 94 150 obviously an inline six reg cab short bed 4x4 it has 140,000 on it looking for tips and advce on building it. should i get a 4.9 motor build it and then swap or can you get good power of the block that is already in the truck with less work.
any links for peformance applications for the straight six to by aftermarket head,cam,intake or others. i've helped friends with their v8's but i'm excited to see what i can do with this "I6" and would apprecate ideas and suggestions thx guys
There is a "universal" EFI management computer called the Megasquirt which will allow you to do all sorts of tuning and mods. Cost is usually in the $500 range to convert from stock. This is not a fully developed "plug and go" product, so there will be a good amount of fabrication and tweaking involved. If you have the dough and patients, switching to an aftermarket computer would allow you to run any sort of cam and exhaust you'd want, plus tinker with injectors and the throttle body.
I can't speak for everyone here but most consider the EFI a somewhat dead-end if you want to do anything beyond a mild warm-up. You can certainly wake up an EFI 300 with a new cam and exhaust, but that's about as far as you can go without very expensive & complicated computer swapping. On older carbed 300's you can select any intake/ carb/ cam/ piston combo you want and build away.
There is currently no aftermarket head for the 300. One is in development but probably still a year from public sale. It's going to be a performance aluminum job with much better flow characteristics. Cost?? God only knows. While you wait you can get noticeable improvements by porting/polishing the stocker.
