smog removal
Old Jan 27, 2007 | 06:11 PM
bigblock345's Avatar
bigblock345
Question smog removal
my air diverter?? is leaking, the rail that runs the length of the head with leads going to each cylinder. can it be removed, cleaned and put back without it leaking between the tube and part that threads into the head?? or will it have to be replaced?? on the other hand, if i remove the smog system completely, plug the holes in the head, will it effect the way the motor runs?? will it confuse the computer system?? it's a 95 model
Old Jan 29, 2007 | 02:00 PM
big blue 95's Avatar
big blue 95
From what i was told and read on some other threads it will be just fine as long as you plug all the vaccum lines and such. Im planning on removing mine but im waiting till the weather is nicer.
