perfomance y-block
Old Jan 28, 2007 | 05:40 PM
kdog134's Avatar
kdog134
perfomance y-block
The 292 in my 1960 f-100 needs replacement. Would like to find a new or remanufactured y-block , with a mild performance upgrade, vintage style preferred, to replace it. Any ideas where I could get one?
Regards
Kevin
Old Jan 29, 2007 | 06:36 AM
FordRacing250's Avatar
FordRacing250
You might be better off rebuilding yours. the P/I heads are nice... do a slight port job and they will be better.. find a nice 2 or 4 barrel intake that will fit a holley, get a cam from isky or clay smith.. put a set of headers on it and a new distribitor, i believe msd makes one and it will SCREAMMMM
Thats what i did.. back when i was in high school
try not to miss a shift... i seen my tach hit 9000 rpm... thought it might of killed it but it was fine.
Old Jan 29, 2007 | 09:57 AM
Snowking's Avatar
Snowking
Try to get a pair of G-heads bigger intakes and smaller chambers for higher compression. Nice to hear someone else is keeping a old Y block.
Old Feb 3, 2007 | 08:13 AM
Walston's Avatar
Walston
Check out Jim Mummert's website on Y-blocks.
Old Feb 3, 2007 | 10:37 AM
59flatbedford's Avatar
59flatbedford
if you want to build it up tear yours down have it decked, bored and put a 312 crank in it with a good cam and either a holly 4 or a six pack and your set. my dad had a 56 ford customline back in high school with a 292 with the heads milled 20 thousands and high compression pistons. i guess that thing really ran when you opened her up.
Old Feb 3, 2007 | 10:38 AM
Snowking's Avatar
Snowking
http://www.y-blocksforever.com/ I occassionally drift by there.
Old Feb 3, 2007 | 10:24 PM
pcmenten's Avatar
pcmenten
Certain late 50's heads will work well; -113, ECZ-G (get the posted ones), ECZ-C. High ratio rockers on the intake valves. Get Mummert's head gaskets and pistons and make sure you're at zero-deck. Go easy with the cam, like a 256 duration. Degree the cam. I tried two different stock chains on a performance regrind from CamCraft and couldn't even get it close. I ended up buying a performance timing set from Mummert.
The iron intakes that fit the Holley 1850's can be found on eBay but the prices keeps going up. The earlier manifolds will fit a Carter WCFB but I haven't worked out how the linkage works with a GM carb. Use a small carb, about 450 cfm, and it will tune easier.
