Exhaust Glow. need some help.
Old Jan 8, 2007 | 07:18 AM
restoringmy46's Avatar
restoringmy46
I posted this on the 47 and older forum and got one responce. So I was going to see what you guys thought. My uncle has got a 1928 modal A. It is all original with the 4 cyl flathead. My dad rebuilt the carb and put it back on. They did adjust the timing some also. It will start and run and after a few mins. the exhaust pipe down from the manifold about 12" it will start glow cherry red. I got a response from R Pope and he said- to turn the gas up some moreor it could be retarded spark or lean mixture or it could be both. And this all make sence so we are going to try doing it tonight. All I was hoping for was one or two more ideas. I don't know alot about the flathead so I was trying to get some info for my dad and uncle. Is this the only 2 things that can cause this. Thanks Scott
Old Jan 8, 2007 | 09:04 AM
F6Guy's Avatar
F6Guy
I would have to agree on the lack of timing advance or maybe an obstruction in the exahust.
Old Jan 8, 2007 | 09:25 AM
Huntsman's Avatar
Huntsman
On later model vehicles the first section of exhaust pipe from the manifold back is sometime double layered. I once had Nova that the inside layer collapsed on, not sure if your's is built this way or not.
Old Jan 8, 2007 | 09:52 AM
WillyB's Avatar
WillyB
It is most likely one of the problems already mentioned, but if not I would check to insure all cyclinders are firing. A miss can send unburned gas into the exhaust, which then burns the rich mixture in the first few inches of the exaust pipe.
Old Jan 8, 2007 | 11:55 AM
brucewolff's Avatar
brucewolff
I think it's probably the timing retarded too much (i.e. not advanced enough).
Old Feb 3, 2007 | 05:34 PM
51ford's Avatar
51ford
Ive run into this before . It could be avacum leak, it would make the engine run lean. try spraying some brake clean at the intake to head gskt. or carb base to manifold. good luck ,mike
Old Feb 3, 2007 | 09:04 PM
pcmenten's Avatar
pcmenten
If the cam isn't timed right, that could make this happen.
Old Feb 3, 2007 | 11:24 PM
RUSTY50F1's Avatar
RUSTY50F1
Sounds like the timing is to slow. RUSTY
Old Feb 3, 2007 | 11:42 PM
lewislynn's Avatar
lewislynn
I don't think too lean (too litle fuel) is the problem with fuel burning in your exhaust. Having fuel burning in your exhaust would mean too much fuel (too rich). You said the carb was rebuilt, you'd better check there first after you recheck your timing.
