Fuel and temp gauges interactive
Old Jan 28, 2007 | 11:31 AM
jeffreysw's Avatar
jeffreysw
On my 1979 F-100, the water temp and fuel gauges appear to be linked up electrically somehow. When the fuel tank is full, the temp gauge reads higher. When the fuel tank is low, the temp gauge reads lower. I put a new fuel tank in it about 6 months ago, so I know the ground at the sending unit is good. I put a thermocouple into the water line leaving the engine (to the top of the radiator) and the temperature is an even 180 degrees F., so I know the thermostat is working correctly.
Any ideas?
Bill Jeffreys
Old Jan 28, 2007 | 12:10 PM
Mil1ion's Avatar
Mil1ion
You need to clean the printed circuit board completely.
Corrosion can cause problem like this.
Also, did you install a Gauge Temp sending unit or a Idiot light Sending unit?
There is a difference.
Note the white stuff on the gauge contacts.
This also happens where the ICVR attaches and it can cause erratic gauge behaviour because it sends the pulsing 5v current to the sending units.
Make sure you clean where the ICVR attaches.
Old Jan 29, 2007 | 03:26 AM
Stratus's Avatar
Stratus
what does ICVR stand for? I noticed I have the white caps on only two of my four gauges, is that normal or should all four have covers?
Old Jan 29, 2007 | 03:50 AM
fatherdoug's Avatar
fatherdoug
Like Dennis's picture states, it stands for "Instrument Cluster Voltage Regulator". My original cluster only had two plastic caps also. I don't know if I was missing two or not.
Old Jan 30, 2007 | 05:42 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
ICVR aka CVR = Constant Voltage Regulator
D1AZ-10804-A [ Motorcraft # GR 513 ]
When the gauges fluctuate, this is one of the culprits.
kabcpapc
1997 - 2003 F150
Sep 6, 2014 03:53 PM
got2befast
Jul 17, 2010 07:10 AM
denjomilay
1983 - 2012 Ranger & B-Series
Jun 29, 2004 08:39 PM
Tedster9
Aug 7, 2002 12:44 PM
matt davis
Feb 21, 2001 11:25 PM
