disc brake conversion
Old Jan 28, 2007 | 11:02 AM
67mercury's Avatar
67mercury
hey i got a 1967 mercury m-100 2wd 352 4 spd , just curious if there is a power brake and disc brake conversion for it an if so what you guys would recommend , also is there a after market power sterring pump to install with all brackets and hardware ?
Old Jan 28, 2007 | 12:15 PM
jowilker's Avatar
jowilker
67mercury, Welcome to FTE The nations Ford truckstop.
The subject has been coverd thousands of times. You may use the search feature and you will see them. There is a tech article on the site about it also.
Welcome aboard!
John
Old Jan 28, 2007 | 02:13 PM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
67mercury
Welcome to (FTE)!
As stated above there is a good artical for this swap.
P.S. mercury trucks very cool! While looking for a donor 73-79 for your brake
parts you may want to watch for one with a FE/360-390 engine for the, pump,steering box and brackets you will be needing, there is also an artical for
the power steering swap, you may want to take a look at it.
Wally Womack
Old Jan 28, 2007 | 09:14 PM
68murc's Avatar
68murc
Welcome fellow Merc owner! Where are you from? These trucks were only built up here in Canada, so it's always interesting to see how far from here they've gotten.
P.S. Make sure you hang onto that Mercury tailgate if you have it.
