Gauge install question?
Old Jan 28, 2007 | 08:29 AM
Flywest's Avatar
Flywest
I have a gauge install question?
Trans temp gauge is in and working!
Next I thought the turbo boost gauge would be second most simple install.
Had to buy my gaugues downunder (VDO brand) to get the imperial versions for our stoopid metric system.
Because of that I didn't get a "kit" as such - just a bunch of individual parts - supposedly everything I need - except it never is - theres always something missing!
So
I didn't get any sort of a "T" piece like depicted above - I suspect they think I'm gonna drill and tap the turbo pipe or something - to get the boost pressure, but that ain't gonna happen if I can just "T" off the MAP line!
Anyone know how, what, where, I can order this T piece and what I specify when I order it from my parts store? (Diameter, barb ID & OD) etc etc...cone tight?..
Just hoping someone knows a easy source or description so I get the right one first time!
Cheers!
Old Jan 28, 2007 | 08:40 AM
alan hodges's Avatar
alan hodges
I think what most of us have done, is go to your auto parts store or hardware store and get the pieces you need. A brass t fitting that is threaded on all three ends. 2 barbed fittings to fit the 1/4 inch line ( I think), 2 small hose clamps,then one fitting that will have a 1/8 compression fitting for you line to the gauge. You should be set. I would also put teflon tape on the threads as well.Good luck Alan
Old Jan 28, 2007 | 08:46 AM
Uzumati's Avatar
Uzumati
Fly not exactly sure on the measurements but this it what you need: http://www.itpdiesel.com/store.php?c...on=show_detail
Shipping will be twice the part probably unless you can find it downunder.
Old Jan 28, 2007 | 08:59 AM
twisted289's Avatar
twisted289
I believe my Autometer came with a useless nylon T that was way too small. Thankfully when I ordered the gauges I asked about the T and they sold the one I needed, 10 bucks for about 4 bucks worth the parts. But I ordered it anyway to save myself the trip to the store. When you buy the parts get the elbow adapter for the hose, otherwise if the hose kinks, its worthless
Old Jan 28, 2007 | 10:58 AM
bigtorque's Avatar
bigtorque
on a second note, you could read boost with the AIH delete kit, w/ boost fitting,
its 29 bucks US. @ www.blackclouddiesel.com
