Differential swap
Old Jan 28, 2007 | 03:23 AM
ladiabla74's Avatar
ladiabla74
Differential swap
Anyone know what newer truck is a good donor for a 70's 2wd f100? I currently have 2.75 gears and would like limited slip with 3.00 to 3.55 or so gears.
Old Jan 28, 2007 | 04:40 AM
Torque1st's Avatar
Torque1st
Posting Legend
You probably have a 9" axle but check your data plate codes. You can get multiple ratios in that range with many types of locker or limited slip for a 9" axle.
Old Jan 28, 2007 | 12:53 PM
75F350's Avatar
75F350
Torque1st has made a great suggestion for your truck. Most guys are replacing the later model axles for the one you have in yours already. It is a strong, reliable unit. A quality gear change can be accomplished for about the same money as a replacement, once you figure in the time it may take to locate a donor, and switch it out. Disc brake kits are even very easy to find for the 9", and they are getting very inexpensive. You have already a good base for a great axle, just fix / upgrade what you have in there already, you will be happier in the long run.
Old Feb 1, 2007 | 10:58 PM
ladiabla74's Avatar
ladiabla74
Guys,
I am completely clueless when it comes to figuring out an axel. can you guys guide me as to what I would need to do to upgrade my existing one? What costs are involved, etc... The only thing I know is that the existing one is a 2.75 according to tag but don't remember if it is a 9" or not. I hope it is. Where can I find quality parts for them at good or reasonable prices? Thanks guys..........
Old Feb 1, 2007 | 11:02 PM
ladiabla74's Avatar
ladiabla74
Also, what is the difference between limited slip and locker or any other kind out there. I need to be schooled on this subject (and many more) lol......
I did read on one of this threads that if the job is not done right it can mean disaster. How difficult is it to get done and what are the odds of getting a good result as opposed to just getting a different axel sealed up from factory?
Phy
Oct 20, 2011 01:36 AM
tskinner
16
Feb 1, 2009 05:29 PM
treb
1983 - 2012 Ranger & B-Series
Aug 28, 2003 09:27 PM
svt522
Feb 14, 2002 09:34 PM
77fordf250
Jan 21, 2002 09:07 PM
