Sponsored by: Real Truck
LIghting Problem. Please help
Old Jan 27, 2007 | 07:43 PM
dishgod's Avatar
dishgod
Hey guys. New guy here. I need some help with my truck. I have a 99 Ford F250 PSD. The interior light stays on, with the door adjar light on the dash. DOme light and cargo light go out at 15mph. All the doors are shut. Any Ideas?
Old Jan 27, 2007 | 07:47 PM
dishgod's Avatar
dishgod
Bump to the top
Old Jan 27, 2007 | 07:56 PM
99f350sd's Avatar
99f350sd
One of your door switches is not working. The sw is under the latch mechanism inside the door. Most guy's try drowning it in wd40 and it seems to work most of the time. I just replaced mine..
Dick
Old Jan 27, 2007 | 07:59 PM
dishgod's Avatar
dishgod
I am not a mechanic, so please forgive me, but are you referring to the latch inside the door, or the external setup?
Thanks for the info.
Old Jan 27, 2007 | 08:00 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Spray the door latch on the door itself with WD40. This is a very common problem with most ALL Fords products more than a few years old. It fixed my '97 Lincioln Mark VIII over 2 years ago. Some have had to let the WD40 work it's magic overnight, but it still works. Start by using a liberal dosing. Open - close door a few times. If it isn't fixed by then, respray and let it sit overnight. Try again. It should be fixed.
Old Jan 27, 2007 | 08:02 PM
dishgod's Avatar
dishgod
Thank you much guys. Appreciate the help!
Old Jan 27, 2007 | 08:11 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Stop back by here and let us know if it worked....thanks!
