Sponsored by: Real Truck
New Ford TowCommand
Old Jan 27, 2007 | 06:40 PM
BMOHIO's Avatar
BMOHIO
New Ford TowCommand
Just installed the towcommand control unit and the master cyl.
Need Help !!!
Bleed the brakes and went for a short drive, the brake peddle fills soft and goes down a little further then it did be for, so i bleed it again and again with no change.
Is this normal for the unit ????
Old Jan 27, 2007 | 08:03 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
NO...bleed right rear first, left rear - right front, finally driver's side front. Don't skimp on the brake fluid. Hope you are using synthic.
