Lost Overdrive
Old Jan 27, 2007 | 05:31 PM
squeege's Avatar
squeege
Lost Overdrive
2000' f-350 super-Duty diesel, automatic. Truck started to slip between 4th and 5th. Then lost overdrive altogether. Transmision shop said it sounds like it could be the torque converter. I have the truck Chipped, he said the standard torgue converters can't handle the extra horsepower. Ever since installing the chip I get intermittent trouble codes. Usually a 3-4 shift error or exhaust gas control high input. The chip is a 'Superchip'. I was running it in the 'Tow-Performance' mode. Anyone experience problems similar to this.
Old Jan 27, 2007 | 06:17 PM
LEVEL10's Avatar
LEVEL10
your 2000 truck has a 4r100 trans and from what you state. to me you have sufferdd from a clutch pack failer. inside there are may things that can and do go wrong with the 4r100 esp. the early ones.
i would reccormend a rebuild in a min.of a stage 2 and a billit convertor for what you are doing and playing with.
check out our web site for more help or call durning normal e.s.t. work hours of 0700 to 1700 hours week days and 0700 to 1200 on saturday for even more help. make sur e you tell our tech man your from fte.
