high flow fuel pumps
Old Jan 27, 2007 | 02:03 PM
Dmford's Avatar
Dmford
hello everyone, I have a 1995 f150 with dual tanks. Has anyone ever tried mustang intank pumps? If not what other options are thier for high flow pumps? Thanks for any help.
Old Jan 27, 2007 | 03:38 PM
quicklook2's Avatar
quicklook2
i would think you do not need them.
Old Jan 27, 2007 | 07:47 PM
Conanski's Avatar
Conanski
The problem with the trucks is the pump is enclosed in a plastic resovoir that contains check valves and you can't remove that resovoir without causing problems. And most of the hi-flow pumps are physically bigger than the original and there is no room for them inside the resovoir. I managed to get a 155lph(can't remember the make) in one of my tanks because it was nearly the same dimension as the OAM, but it only lasted a year. If your truck only has 1 tank you should be able to make something work though.
