Switched to manual steering...what to do about belt/pump pulley?
I converted to manual steering on a 88 1/2 ton 302 and I am not sure what to do about the belt. If I run a shorter belt (the easiest thing to do) then water pump to belt contact drops a bit and it will be prone to slip.
What I would really like to do is come up with an idler pulley to put in place of the pump but I can't seem to come up with anything.
Any ideas on how to fab one??
Suggestions??
Suggestions??
ok i haven't looked into how the pump is bolted to the block but could a a/c compressor bypass pulley such as motormite part number 34150 work?
https://www.dormanproducts.com/cgi-b...tegory_list=:0
[QUOTE='88_F-150]ok i haven't looked into how the pump is bolted to the block but could a a/c compressor bypass pulley such as motormite part number 34150 work?
https://www.dormanproducts.com/cgi-bin/vm91corp30r/item-dtl.w?sid=0x00434493&item=34150&icrid=&clt=hwrap1& vsrch_str=34150&vsrch_brand=ALL&vsrch_cat=ALL&st_a mount=&end_amount=&start=&vfrom=&prev=&vnext=&cate gory_list=:0[/QUOTE]
The link does not seem to work for me.
No the AC eliminator pulley will not work without drastic modification and fabrication. It would be easier to fabricate a pulley and bracket from scratch...
BurnerDoc
01-26-2014 03:01 AM
trotsky13
28
11-29-2009 07:04 PM
SmokeBlower
05-24-2008 11:14 AM
rallyXR
02-16-2004 07:09 PM
