Sponsored by: Auxito
Bad Brakes?? Please help
Old Aug 17, 2001 | 06:03 AM
jmfifield's Avatar
jmfifield
Old Jan 2, 2003 | 12:03 AM
littlemadi's Avatar
littlemadi
I have a '99 F-150. I have the classic lerching problem when I brake. I notice it at slower speed i.e. about stopped. But I also notice that at higher speeds such as on the highway when I touch the brakes it feels like that back end kind of jumps a little. It is almost like a vibrating sensation. I only get this feeling at higher speed, when I am almost stopped I get the lerching. I have replaced the fron brakes and still have the problem. I plan on chainging the the rear brakes too but could it be something else?? thanks for any help...
Old Jan 2, 2003 | 06:33 AM
aldridgec's Avatar
aldridgec
Could be the rear brakes are out of adjustment if they are drum. Or an axle seal is bad and the brakes are grabbing.
Old Jan 2, 2003 | 09:13 AM
Racerguy's Avatar
Racerguy
Sounds to me like you've got warped rotors or drums. Either have them turned or replace them.
Old Jan 5, 2003 | 11:54 PM
melvin2112's Avatar
melvin2112
I had the same problem on my '97 F-150 following a front brake job. I took it back and had the rotors re-surfaced. It seemed to solve my "lerching" problem.
Old Jan 6, 2003 | 10:57 PM
Torque1st's Avatar
Torque1st
Posting Legend
More info placed in a sep post that was removed:
I have a 1999 F150 2WD. When I am traveling at highway speeds and start to brake the back end starts to vibrate, shudder, and shimmy a lot, as I slow down it turns into more of a pulsating feeling (this all only happens when I am brkaing). I have changed both the front and rear brake and have put new drums on the rear. When I changed the drums I noticed that the driver side Lug plate (plate where my lug bolts are mounted)and assembly moves inward and outward from the axle a little. The passenger side did't do it. After I changed the brakes and drums I still have the problem. Could the extra play in this area be a bad bearing? Could this be causing my problem? Please help, I don't know what to do.
The other post had one reply from user Deebo:
The Axles have end play like that. I would say your tires are out of round.
<Added by Torque1st, [link:www.ford-trucks.com/guidelines.html|FTE Moderator]>
Grease or oil that was not removed properly with brake cleaner can also cause this problem. Resurface your drums and/or rotors.
