1978 - 1996 Big Bronco
lockers?
Old Jan 17, 2003 | 01:25 PM
skitz's Avatar
skitz
lockers?
how do i know if i have lockers?
Old Jan 17, 2003 | 01:33 PM
Jeepincj7's Avatar
Jeepincj7
lockers?
Old Jan 18, 2003 | 03:20 PM
2001ExcursionV10's Avatar
2001ExcursionV10
lockers?
Your wallet will be a little light
Old Jan 19, 2003 | 12:16 AM
spixican07's Avatar
spixican07
lockers?
heh. that was witty.
seriously though. get your car in the air (lift preferably, jack stands otherwise) and rotate your drivers side tire manually. if your passenger side tire rotates in the oppoisite direction, you have some sort of non-open differential.
as far as what type, if youre the original owner and you havn't put any in, you don't have lockers. they didnt come with them from the factory.
if youre a second owner, check the paperwork. if that isnt an option, then listen carefully when you take a hard turn. if your tires chirp you may have a locker.
besides that, the only other thing i can think of is to just open the differential housing and look at the carrier. lockers look a lot different than limited slips or open differentials. check around on the net and you should be able to find quite a few pictures.
lastly, if all of that stuff fails. take it to a mechanic and have him figure it out.
hope that helps buddy.
Old Jan 19, 2003 | 08:41 PM
83Steve's Avatar
83Steve
lockers?
Actually, that would indicate an open diff. If there's ANY traction-aiding device in the diff, the wheels will spin the SAME direction (assuming the trans or t-case is in neutral) with no load, like that test.
Old Jan 19, 2003 | 11:05 PM
spixican07's Avatar
spixican07
Thumbs up lockers?
there ya go. i stand corrected
Old Jan 19, 2003 | 11:10 PM
nolanc2's Avatar
nolanc2
lockers?
83Steve is right when you lift the front/rear axel spin one tire by hand if the opposite tire spins the other direction you have an open diff if they spin the same direction you have some sort of locker.
If you don’t feel like lifting the truck put one tire in the grass and one on the pavement and give it a little gas if all it does is tear up the yard you don’t have a locker.
I recommend using your on yard for this one, It easer to explain it to your wife than the cop.
