6.0 throwing a code
Old Jan 26, 2007 | 06:27 PM
dr501's Avatar
dr501
Question 6.0 throwing a code
i have a 2004 6.0 psd havent had any trouble so far 67000 miles on it with the edge with attitude hooked up for over a year it just threw a (p2285) code injector control pressure sensor circuit low could i get a lil bit of info on it and needs 2 reflashes done injecor one and a nother
thanks
Old Jan 26, 2007 | 06:38 PM
BowTieHatr's Avatar
BowTieHatr
first off welcome abord doc.
if your icp sensor is under the turbo, it has probably started leaking. you need to address this quickly, because if it busts you will bath your engine in oil.
Old Jan 26, 2007 | 06:41 PM
dr501's Avatar
dr501
is it a pain to do? i was way to fermilure with the 7.3
Old Jan 26, 2007 | 06:47 PM
BowTieHatr's Avatar
BowTieHatr
take it to a dealer. you save alot of money by doin so. its under the 5/100000 $100 deductible. the sensor is around $350 i believe
Old Jan 26, 2007 | 06:51 PM
dr501's Avatar
dr501
a lil more info just thought of im due for an oil chang also i notesed it when it got colder here in mich when its pluged in it dont show the check engine light i can delet the code when its warm and no light
Old Jan 26, 2007 | 06:53 PM
BowTieHatr's Avatar
BowTieHatr
i still say icp sensor. seen to many leak.
Old Jan 26, 2007 | 06:56 PM
dr501's Avatar
dr501
ok ill look into it thanks what is it tha high pres oil system?
Old Jan 26, 2007 | 07:00 PM
BowTieHatr's Avatar
BowTieHatr
yep. it is a pressure reading of your injection pressure
