battery drain, short?
Old Jan 26, 2007 | 03:35 PM
jrtoy's Avatar
jrtoy
New Battery, hooked up to tester at Advanced auto, they said alternater bad. Took off alternater and had it bench tested, test showed alternator good?!
wiring on one of the headlights looks wrong. Excessive noise coming through radio. battery cable corrode excessively. Sometimes turn signal blink very slowly. Also looks as if someone did a midnight wiring job installing trailor lights hookup.
Could swapped connections on starter relay cause such a thing?
74 econline van, 302.
I'm at the end of my rope on this. Any help would be greatly appreaciated!
******** type="text/javascript"> <!-- Serve300x250( 0, 101, "9664575281" ); //--> </script>******** type=\"text/javascript\" src="http://pagead2.googlesyndication.com/pagead/show_ads.js"></script><iframe name=\"google_ads_frame\" src="http://pagead2.googlesyndication.com/pagead/ads?client=ca-pub-6539444466526181&dt=1169846949218&hints=Help%2C%20 short%20in%20system%3F%20battery%20drains%20-%20Ford%20Truck%20Enthusiasts%20Forums&lmt=1169846 947&alternate_ad_url=http%3A%2F%2Fcampaigns.ford-trucks.net%2Fcampaigns%2F300x250.html&format=300x2 50_as&output=html&channel=9664575281&url=http%3A%2 F%2Fwww.ford-trucks.com%2Fforums%2F572851-help-short-in-system-battery-drains.html%23post4357403&color_bg=FFFFFF&color_te xt=000000&color_link=0000CC&color_url=0000FF&color _border=FFFFFF&ad_type=text_image&ref=http%3A%2F%2 Fwww.ford-trucks.com%2Fforums%2Fnewthread.php%3Fdo%3Dnewthre ad%26f%3D62&cc=100&u_h=1024&u_w=1280&u_ah=987&u_aw =1280&u_cd=32&u_tz=-360&u_his=11&u_java=true&u_nplug=6&u_nmime=15" marginwidth="0" marginheight="0" vspace="0" hspace="0" allowtransparency="true" frameborder="0" height="250" scrolling="no" width="300">
</iframe>
Old Jan 26, 2007 | 08:28 PM
ReAX's Avatar
ReAX
I would first suspect the grounds. Alt case to block, block to frame and finally frame to battery. If the rest of the elec system works, I would suspect the frame to battery connections/wire.
Old Jan 27, 2007 | 06:11 AM
jrtoy's Avatar
jrtoy
Thanks! sounds like a good spot to start.
Old Jan 27, 2007 | 08:39 AM
mrfixit64857's Avatar
mrfixit64857
Battery cable corroded...that says it all to me. Fits in perfectly with what ReAX says as well. If the corrosion has gotten to the cable (turned copper green, etc) it's time to replace it. clean all the above-mentioned contacts well!
Old Jan 28, 2007 | 02:42 AM
rebocardo's Avatar
rebocardo
You did not state that the vehicle is not starting, but, I will assume it is not.
There is suppose to be a large Radio Interference Capacitor on older vehicles. Maybe yours is missing or bad.
As for the proper wiring technique, read my posts here, especially the first link which you might find useful.
https://www.ford-trucks.com/forums/4...y+gauge+ground
https://www.ford-trucks.com/forums/2...y+gauge+ground
https://www.ford-trucks.com/forums/9...y+gauge+ground
beyacork
Nov 3, 2010 01:28 AM
Randy5556
Sep 3, 2008 07:30 PM
PAPA Tony
Mar 25, 2008 09:00 PM
polarisman
Nov 1, 2007 08:19 AM
