Failing Emissions Test
Old Jan 25, 2007 | 11:24 PM
Frank Martin's Avatar
Frank Martin
My '88 F-150 with a 4.9 and Borg-Warner T-18 four speed just failed an emissions test. Carbon monoxide and hydrocarbons, the only two gasses measured, were both high. However the problem only occurred at the idle speed portion of the test. At 2500 RPM everything checks out. The check engine light illuminates at idle, but goes out above idle under power. The check engine light will remain illuminated above idle speed if the throttle is closed, such as when coasting down a hill. I have not yet read the trouble codes. Does anybody have any ideas about this?
Old Jan 26, 2007 | 12:15 AM
EPNCSU2006's Avatar
EPNCSU2006
Go ahead and read the trouble codes and see what comes up.
Old Jan 26, 2007 | 07:20 PM
mississauga's Avatar
mississauga
One thing that comes to mind is that the cat converter was not hot enough before the test was started.
