water pump
Old Jan 25, 2007 | 10:55 PM
my79f's Avatar
my79f
water pump
are there any special tools that i will need for replacing the water pump? any that are out of the normal.
thanks, Austin
Old Jan 26, 2007 | 06:54 AM
Uzumati's Avatar
Uzumati
You can "rent" a tool that will make getting the fan off a little easier but it is not needed a strap wrench and larges channel locks.
Old Jan 26, 2007 | 08:49 AM
twisted289's Avatar
twisted289
Like Alan said!!!! I did mine in my 99 and it took an hour and a half, make sure you have all gaskets before install and it will go quick. If I remember right the fan is reversed threads. Hopefully someone will chime in with a good memory. Good Luck
Old Jan 26, 2007 | 10:42 AM
Highmark18's Avatar
Highmark18
Here you go, check out this link, I did mine a few weeks ago...
https://www.ford-trucks.com/forums/5...ght=water+pump
One thing to note: It is not reverse thread, at least mine wasn't-just keep that in mind, and good luck
Old Jan 28, 2007 | 10:03 PM
my79f's Avatar
my79f
well so i did it without any problems besides forgetting to hook the coolant hose backup that goes on the bottom of that clear fill tank ontop of the radiator. other than that it only took about an hour and ahalf thanks guys to all yall's help.
Old Jan 29, 2007 | 09:37 AM
HP junkie's Avatar
HP junkie
Thanx for the link it will come in handy as I have to replace mine as well. Where did you get your replacement pump from? One better than the other or OEM just fine?
Old Jan 29, 2007 | 01:53 PM
Highmark18's Avatar
Highmark18
Got mine at O'Reillys for 130.00, Ford wanted 270.00
Old Jan 29, 2007 | 06:00 PM
Uzumati's Avatar
Uzumati
Heres the one piece from Orielly's it does away with the lower extension tube and gasket and it has a lifetime waranty
jdbanks
Texas Chapter
118
Aug 23, 2011 07:53 PM
mkrog
Minnesota Chapter
Dec 23, 2009 10:55 AM
Spud
1983 - 2012 Ranger & B-Series
Dec 12, 2006 10:33 PM
davidc-austin
Jan 11, 2005 06:23 PM
skinsey
Texas Chapter
Mar 13, 2003 12:17 PM
