Firewall, Speed Control Wire Question, Reverse gear lamp Question HELP!!
Old Jan 25, 2007 | 07:22 PM
Square Grouper's Avatar
Square Grouper
OK, installing a DVD unit in the dash of my '06 F-250 C/C 6.0 PSD. I am also adding a navigation unit to it as well. The navigation unit has a wire that needs to tap into the Engine Control Computer vehicle speed signal wire. How do I find this wire?
Another wire needs to tap into the + terminal for the reverse gear lamp that is only fed when the trans in in reverse. How do I find this wire?
Finally, where is a point on the firewall where I can run a hot off my battery for my Amp?
Hopefully with a little help, I can complete this install on my own. Thanks!
Old Jan 25, 2007 | 10:36 PM
Franklin2's Avatar
Franklin2
Look under the hood at the driver's side front, and see if you have an abs module. Going into the module should be a lightgreen/red and a lightgreen/black wires. These wires come from the rearend speed sensor.
Old Jan 25, 2007 | 11:05 PM
Franklin2's Avatar
Franklin2
For the reverse lamps, do you have an autodarkening rearview mirror? If you do, look for a black/pink wire running up to the mirror. This has 12 volts when in reverse.
Old Jan 26, 2007 | 06:24 AM
Square Grouper
Thanks!! Which one should I tap into?
Old Jan 26, 2007 | 10:16 AM
Franklin2's Avatar
Franklin2
What type of navigation unit is it? Possibly they have instructions for Ford models on their website?
bmwboyee
Dec 28, 2013 10:47 PM
dzaharias7681
2004 - 2008 F150
Apr 17, 2011 08:19 PM
fst96se
Aug 10, 2010 07:52 AM
TIKT B8
Jun 17, 2010 12:37 PM
pminne
Feb 25, 2010 07:53 AM
