Keep cooking volt regulators
Old Jan 1, 2007 | 04:50 AM
catskillgutpile's Avatar
catskillgutpile
I have an 83 351W that was recently rebuilt with a little more than stock in mind. I keep cooking the external voltage regulator.
The motor is as follows:
83 F 250 4x4
600cfm holley, elec. choke
edelbrock dual plane intake
M-Select 2 cam kit (torque)
K/B pistons @ 9.0-1
Hedman full lenth headers
Still use the durapark box and dizzy with a MSD 2 coil
Stock alternator, which the dash gauge says is working.
I am electrically challenged, so please bear with me. Could this regulator problem be caused by a bad or incorrectly attatched wire? Is the problem with that MSD 2 coil? To much heat from the headers?
This is the second "Heavy Duty" regulator in 6 weeks. The only way I can tell its going south is that the truck is wearing down the battery and leaving me pop-starting her.
Any help is appreciated.
Thanks,
Mike
Old Jan 1, 2007 | 07:26 AM
HemiEater's Avatar
HemiEater
pull the (-) cable off the battery and put a test light between the cable and battery. with everything off doors closed the light sshould not come on, if it does you have a draw on the battery. Could be a trunk light, glove box light, bad alt. I start pulling fuses until the light goes out. go from there....
just an idea.......
Old Jan 1, 2007 | 07:29 AM
catskillgutpile
Will do. Thanks
Old Jan 1, 2007 | 08:48 AM
bronco521's Avatar
bronco521
check and make sure all your grounds got hooked back up.a friend of mine "accidentally" hooked a ground strap up to a hot.thats not too good on batteries,it turns out.
Old Jan 1, 2007 | 09:15 AM
catskillgutpile
Ok, charged bat. up and checked between the neg. cable and neg. post while unconnected. Dang light lit up! Very dim and pulsing. Am going to pull fuses. Any idea what might draw intermitently ?
Old Jan 1, 2007 | 10:29 AM
catskillgutpile
I pulled all fuses and no difference is made. Light still pulses intermittently(spl.) .
When I pull a fuse , close door , then check between the neg. cable and post, the light is bright for a split second then reverts to the intermittent , dim light as described before. So i kept going. I disconected the small lone wire that goes to the starter switch/relay on the fender. No change. Then I unplugged the coupling that is right under the switch/relay and it stopped!
Does this indicate a bad alternator or something in the duraspark box gone bad?
I have digital pics of the plug but can't seem to upload them.
Old Jan 1, 2007 | 10:30 AM
bronco521's Avatar
bronco521
i have done this with a digital volt meter before.i think there will always be a "little" draw some where.just have to start unplugging stuff .could take the hot off the starter and alternator too .they can short out and still work.
Old Jan 1, 2007 | 11:05 AM
HemiEater's Avatar
HemiEater
that sound normal almost..........try and find what it is exactly that is lighting up the light. like I said it sounds normal.....could be a memory thing some where.....
So if we say that is normal now we need to check the alt output. start it and hook a volt meter to the battery you should have somewhere near 14.2 volts all the time...
go from there..................
Old Jan 1, 2007 | 02:26 PM
catskillgutpile
Bat. has 14.3 in it. Showed 10.5 under start load. But only showed 12.3 charging. Should be 13.5 or so , right? How do I test the alternator and regulator? Does that 12.3 when running indicate a bad alt.? Didn't change if at idle or I brought rpm to 3000.
Old Jan 1, 2007 | 02:30 PM
HemiEater's Avatar
HemiEater
It's not charging it should be like 14.2 when running, or there about...take the alt to a shop and get it tested or do like most just replace it with a new reg.....
Old Jan 1, 2007 | 02:31 PM
HemiEater's Avatar
HemiEater
do a load test on the battery too. If it's weak replace that too. if the battery is junk it will over work the charging system.
Old Jan 1, 2007 | 03:04 PM
catskillgutpile
Bat. is new . Broke down on me at a true value last time so I got an interstate 850 amp. It load tested fine. Would a bad alt cook or appear to cook the reg. ?
Thank you very much for your help. I appreciate it.
Mike
Old Jan 1, 2007 | 03:10 PM
HemiEater's Avatar
HemiEater
yup.....stop by an auto zone and have them test it.......
Old Jan 1, 2007 | 05:51 PM
catskillgutpile
Thanks again.
Old Jan 2, 2007 | 04:58 PM
Franklin2's Avatar
Franklin2
You can take the wires off the alt and try your testlight again. If the alt has a shorted diode, it will put a draw on the battery.
