slip yoke question
Old Jan 25, 2007 | 06:23 PM
phatf250's Avatar
phatf250
slip yoke question
is the female part of the slip yoke suppose to have 2 teeth missing across from each other . i posted the other day about a vibration in the rear and tracked it down to the slip yoke . if you grab the drive line , you can move it back and forth alote , i greased the heck out of it and it still does it . think i need a new yoke ?
Old Jan 25, 2007 | 06:27 PM
bloomy63's Avatar
bloomy63
Mine has the two teeth missing as well. I think it is normal. There is a blue coating on the male end of the slip yoke, does your's still have it?
Old Jan 25, 2007 | 06:33 PM
phatf250's Avatar
phatf250
slip yoke
yes it has it just a little though
Old Jan 25, 2007 | 06:35 PM
ron's power stroke's Avatar
ron's power stroke
how is the shafts center bearing???
Old Jan 25, 2007 | 06:37 PM
phatf250's Avatar
phatf250
just changed it out . and new u-joints also . is the yoke supposed to be sloppy
Old Jan 25, 2007 | 06:40 PM
ron's power stroke
it should slide in and out kind of snugg but not alot of wiggling side to side..is there alot of slop if you try to twist the 2 ends against each other???
Old Jan 25, 2007 | 06:43 PM
phatf250's Avatar
phatf250
its not realy snug its loose and it wiggles a good 3/16 of an inch
Old Jan 25, 2007 | 06:45 PM
phatf250's Avatar
phatf250
yes there is a lot of slop if you twist them against each other
Old Jan 25, 2007 | 06:50 PM
ron's power stroke
id say it was time for a shaft then...the shaft should not be sloppy enouph to fall out but it does need to slide in and out with a little effort like a shock..
Old Jan 25, 2007 | 06:54 PM
phatf250's Avatar
phatf250
a new frive shaft or new yoke>?
Old Jan 25, 2007 | 07:00 PM
phatf250's Avatar
phatf250
a new drive shaft or new yoke>?
ron's power stroke
realy hard telling with out seeing what it is doing..im a believer in fix it all or dont bother..if i have a bad leaf spring on one side i replace the hole pack and i do both sides...id get the hole shaft but thats your call..
Old Jan 25, 2007 | 07:11 PM
phatf250's Avatar
phatf250
how much do you think that would be ?
Old Jan 25, 2007 | 07:20 PM
ron's power stroke
found this one on the 1st site i looked at.. http://www.trademotion.com/partlocator/index.cfm?action=getLocatorKeySearch&siteid=214290 &chapter=DP2171&catalogid=1&year=1999&make=10&mode l=F350not sure what you have for a truck..but look around at our sponsers web sites...
Old Jan 25, 2007 | 07:23 PM
Kwikkordead's Avatar
Kwikkordead
When I had my drive shaft apart two weeks ago the splines were very snug. Absolutly no slop side to side. And it was a bit of a tug to get the two halves apart.
If my shaft was as sloppy as yours is, I would be replacing it.
