Coolant filter?
Old Jan 25, 2007 | 12:25 PM
Pele's Avatar
Pele
Coolant filter?
I seem to recall seeing here or somewhere the modification adding a coolant filter to our cooling system.
The installer Teed into the heater core lines.
It went something similar to the following:
Code:
Out from engine------------------|----------------|
			     Ball Valve 	   |
			       Filter 	       Heater
			     Ball Valve 	   |
Return to engine------------------|----------------|
I had a few questions as to why someone would do something like this:
Not all the coolent goes through the filter, how does this make the filter at all effective? In the oiling system, the oil comes from the pump and goes DIRECTLY through the filter, do not pass go, do not collect $200... In the event the colter is clogged, the filter has the bypass valve inside.
In the cooling system, not only does not all of the coolant go through the filter, but not all of the coolant comes out the heater passages either.
I can understand it would be a bad day if the filter blocked up and it were in line like the oil system rather than a bypass setum like this... But couldn't it have a bypass valve?
And what of putting it in the radiator line rather than the heater core line. Wouldn't that catch more junk. If the flow is too low, how about two filters in parallel?
And finally, is junk in the cooling system that much of an issue? Every time I've drained coolant from one of my gassers, crud has been from a corroding out radiator which'd need to be replaced anyhow. The radiator in the F350 is new. Changing coolant every few years should keep it that way.
Old Jan 25, 2007 | 01:05 PM
PLC7.3's Avatar
PLC7.3
When these engine blocks were made they were sand cast.... consequently there is/was sand circulating through the cooling system. Damage to the water pump etc was seen so the filter system was installed aftermarket. With the filter install came the option to induce SCAs at a regular interval to retain the numbers required over a period of time. If your truck has been flushed several times it could be clean but any time you open the system there is a chance of gasket sealant scrapigs, dirt etc getting in the system. It's just cheap insurance for those who want it.
http://www.baldwinfilter.com/engineer/00_1.html
Old Jan 25, 2007 | 02:48 PM
dieself250's Avatar
dieself250
I have coolant filters installed in my trucks and was suprised how much crap the filter catches in an alredy clean system i had to replace the filter once a month for 3 months to get all the grit out
Old Jan 25, 2007 | 04:51 PM
MSC1's Avatar
MSC1
dieself250--- where are your filters located?
Old Jan 25, 2007 | 05:06 PM
dieself250's Avatar
dieself250
under the hood
Old Jan 25, 2007 | 05:10 PM
gumboluvr's Avatar
gumboluvr
Pele,
I agree with you. I might be able to understand a filter in series, in either the heater supply or return line, but they way you show it with ball valves and stuff seems useless. What do I know?? I am just a Dumb A## Electricain
Old Jan 25, 2007 | 07:34 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Looking at the drawing Pele did it looks like you can shut the water off to the heater in the summer and run the coolant through the filter. In the winter shut the filter off and run the coolant through the heater.
I could see that working.
dieselF250,
That looks like a nightmare for the plumber. There are so many tee's I have to wonder how well the heater works.
Water out of the head which can go either to the heater or come to the front of the truck, then splits again either to the filter or down to something else.
Where does that line go?
And how does the coolant get back into the cooling system from down below?
Old Jan 25, 2007 | 08:04 PM
dieself250's Avatar
dieself250
heat output is great
the T closest to the battery goes down to a check valve then to a coolant heater that is connected to the bottom of the block neer the starter. when i plug in the heater the coolant flows out from the bottom of the block through the heater, through a check valve , to the heater core and into the head. best of all it keeps the snow off my winshied when parked
i need to take some new pics, i made the plumbing look better when i added a/c to the truck
Old Jan 26, 2007 | 03:01 AM
Pele's Avatar
Pele
No no no... The water is ALWAYS flowing through the heater.
The ball valves are so that one can remove the filter without getting too much coolant everywhere...
EDIT: I found the link to where I originally saw this installation:
http://www.dieselwarden.net/ford/coolfilter1.html
Old Jan 26, 2007 | 10:33 PM
Barehuggs's Avatar
Barehuggs
Originally Posted by gumboluvr
Pele,
Another Electrician???? There seems to be an abundance of us on this board.
How Far from ElDorado, AR are you?
Old Jan 27, 2007 | 01:56 PM
Dave7.3's Avatar
Dave7.3
How often do you think you would be changing the filter on that coolant system? I'm thinking, after reading the literature that Pele posted, it might be a good idea to install a filtering system on my rig...
Old Jan 27, 2007 | 03:39 PM
dieself250's Avatar
dieself250
i had to replace it every month for 3 months, now it looks like i should be able to change it twice a year. easy way to see if it needs changing is to feel it. if it is the same tempature of the hoses its good and if its cold its cloged
Fixnstuff
Nov 12, 2018 11:23 AM
ElMoco
46
Nov 28, 2016 09:42 PM
BryanStein
Sep 23, 2015 10:54 PM
Bread
Mar 7, 2012 10:11 AM
hrkdrivr
Dec 23, 2010 12:48 AM
