Modular V10 (6.8l)
larger fuel tank
Old Jan 25, 2007 | 10:07 AM
ron86toy's Avatar
ron86toy
larger fuel tank
I have seen them for deiselsbut not for a v10 application...I have the short bed with the 28? gal tank.I have seen upgrades to 58 gal but can only find it for deisel.Anyone know if I can use that tank or have a link to someone that makes one for a gasser.
Thanks in advance
Old Jan 25, 2007 | 11:23 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
The problem with gasoline tanks is the evaporative emissions stuff and the manufacturer getting certified/cleared for it.
I'm pretty sure there was a maker of gas tanks for these things, but I can't remember who now. Transfer-Flow? But I think someone else said they only make diesel tanks.
Guys?
Old Jan 25, 2007 | 11:35 AM
ron86toy's Avatar
ron86toy
I just checked Transfer-flo........$1000.00 for a 46 gallon
I seen the a tread on someone did a 58 for around 600.00(short bed deisel),wich IMO is more reasonable.I would rather make a few extra stops during the week than drop 1000.00 for 18 gals.
Old Jan 25, 2007 | 01:15 PM
i eat hybrids's Avatar
i eat hybrids
Whats the difference between a diesel and gasoline tank?
Old Jan 25, 2007 | 02:10 PM
krewat's Avatar
krewat
Evaporative emissions on gasoline. Not sure about diesel, but I'm sure it's much much different.
For instance, I know large truck diesel tanks have no breather whatsoever - don't need it, either. There's not as much vapors with diesel (if any) and it isn't as flammable as gas vapor.
I'm not suggesting it, nor do I condone it, but it probably wouldn't be too hard to fab something up using the original stuff as a guide. But screwing with that stuff might get you failed in an emissions visual inspection.
Another reason aftermarket might not supply gas tanks? Because of the liability in an accident. I wonder how much of that $1000 goes towards Transfer-Flow's insurance policy?
Old Jan 25, 2007 | 03:27 PM
ron86toy's Avatar
ron86toy
In Mi we do not have emission inspections...so i am not worried about that...but if the diesel tank can work with a little fab it is worth looking into,the 58 gallon tank would double my capacity.
Old Jan 25, 2007 | 04:08 PM
krewat's Avatar
krewat
Keep in mind what happens in an accident, and if that tank, filled with gasoline is not a bomb waiting to go off...
Old Jan 25, 2007 | 04:32 PM
ron86toy's Avatar
ron86toy
I do understand that...as with any tank,like the aux. tanks in the bed that are basically diamond plate.That 58 gal fit in place of the factory tank,came with a skid plate and hooked to the factory filler....I will try and find the tread in the SD section and post a link
Old Jan 25, 2007 | 04:36 PM
ron86toy's Avatar
ron86toy
here is the tread I was reading
https://www.ford-trucks.com/forums/5...ight=fuel+tank
and the tank I am looking at
http://www.aerotanks.com/inv/1019.htm
Old Jan 25, 2007 | 09:08 PM
sewerat's Avatar
sewerat
what about taking a tank from an EX and making it work? can't be that different? the ex's have a 46 gal tank?
Old Jan 25, 2007 | 09:14 PM
ron86toy's Avatar
ron86toy
I always thought the EX tanks were mounted behind the axle.....maybe something to chek out
Old Jan 25, 2007 | 09:16 PM
sewerat's Avatar
sewerat
yes it is behind the axel, that would be y my spare is in the back, but could you still not make it work?
Old Jan 25, 2007 | 09:27 PM
ron86toy's Avatar
ron86toy
yeah.... quik search I found that out,not sure on dimensions of it but I am pretty sure it sits between the frame rails.that would come into play with the d-shaft since the filler neck is in front of axle.
I have been trying to find pics of the top of the diesel and gasser tanks to see the differance.I now venting will not be a problem since it is just the filler neck and cap used for the vent now
Old Jan 26, 2007 | 10:04 AM
PROSTOCK's Avatar
PROSTOCK
The "X" tank is 44gal and sits behind the axle between the frame rails, the filler is near the back corner of the truck....the spare is mounted inside. Probably doable, but a lot to go through for just 16 more gals.
Years ago I made a tank for my '78 Bronco. It mounted in the same place as the original but was much larger. It took 41gal, the original was 33.
