Squeaky body mounts, fix available?
Old Jan 25, 2007 | 10:00 AM
EpicCowlick's Avatar
EpicCowlick
I have a 2000 Limited with 140,000 miles. The body mounts under the feet of the driver and front passenger squeak like a stuck pig when the truck flexes at all (like every corner or dip in the road). I looked under the truck and can see the rubber mounts but I can't tell how to get them off to grease them up. Does anyone know of a way to take them off to service them? Are there any polyurethane replacements? Mostly I just want to know how to get to the bolts that hold them on.
Old Jan 25, 2007 | 10:29 AM
BAJI26's Avatar
BAJI26
under the driverside floor mat there is a black grommet, you can remove that grommet and tighten the mount there and spray some sillicon.
Old Jan 25, 2007 | 11:48 AM
EpicCowlick
I guess you have to lift the carpet up which sounds like a pain to me. Probably have to remove the plastic side panels and whatever else?
Old Jan 25, 2007 | 02:17 PM
BAJI26's Avatar
BAJI26
Remove the plastic molding and the carpet which is easy, should take 3 minutes to do that.
Old Jan 26, 2007 | 12:21 AM
RACERX7775's Avatar
RACERX7775
i did the same on my 01. it takes like 2 minutes.. and thats to reinstall it too. i removed the bolt, poured engine oil on it. reinstalled the bolt, it stopped for a couple days. i think that its the bolt rubbing on the metal. not the mount itself. i think it needs some never seize.
Old Jan 26, 2007 | 09:21 AM
EpicCowlick
I was thinking that I'd put a jack under the body and lift it up off the mounts a little. That would give some space to put some grease or something in there. Wonder if that would last longer?
Old Jan 30, 2007 | 11:53 AM
BAJI26's Avatar
BAJI26
Well after I did mine I haven't had a squeek in about 6 months.
nmlongbow
Nov 19, 2017 01:06 PM
snotrod
Nov 14, 2016 01:41 PM
Gater180
May 23, 2016 04:15 PM
BAJI26
Jun 16, 2015 08:17 AM
CPB1
May 30, 2014 07:42 PM
