Sponsored by: Real Truck
Ford Nerf Bars fell off
Old Nov 7, 2016 | 09:01 AM
snotrod's Avatar
snotrod
My passenger side nerf bars broke off. The mounts are still solidly attached to the truck. I checked the drivers side, and only 1 of the 3 mounting points on the bar are still solidly connected so I just pulled and it came off too.... all of the body side mounts are still solid. I have a "vertically challenged" wife and need to get these back on asap. Anyone know how to attach the bars to the mounts? Looks like whatever bolts were there are broken, or sheared off.. I just can't figure out how to get to the back side of the bolts.
TIA
Old Nov 7, 2016 | 12:40 PM
02F250V10's Avatar
02F250V10
On my truck the original nut inserts in the bars rusted out but the mounts were still solid. I just slid the bars an inch or so forward so i had solid metal to attach to and ran a few self tappers through the mounts into the bars. Held up fine for a couple years now
Old Nov 14, 2016 | 12:50 PM
snotrod's Avatar
snotrod
thank you for the response. anyone else have anything to add?
there's multiple hole locations in the bar, so i'm guessing this isnt the first time it's happened
Old Nov 14, 2016 | 01:02 PM
NewEnglandHerdsman's Avatar
NewEnglandHerdsman
Not sure what bars you have, but... I have the oval ones, I had one of the threaded inserts corrode and fall out. I cut a piece of like 16 gauge steel about 1.5" square, hammered it to the right contour to fit inside the tube. Drilled a hole in it, welded a nut to it, then fished it to the right spot to run a bolt up through the bracket. Nice and solid, won't pull out.
Old Nov 14, 2016 | 01:06 PM
cyncwby's Avatar
cyncwby
Nerf bars?????? or are you talking about the steps?
Old Nov 14, 2016 | 01:41 PM
snotrod's Avatar
snotrod
yeah. I have the oval ones too..
diamond dogs
Sep 19, 2018 03:26 PM
macrobatic
Mar 7, 2017 01:16 PM
AtomicNo13
Feb 1, 2014 05:53 PM
Cowboy34
WTB - Parts & other
Jan 12, 2010 06:30 PM
Ranger Louie
Aftermarket Products
Oct 10, 2004 10:44 PM
