IFS leakin gear fluid
Old Jan 24, 2007 | 06:52 PM
clunker86's Avatar
clunker86
i have a 1986 f250 4x4 with a diesel body. i notice today when i pulled up that i am leaking rear end fluid around my pumpkin on the driver side. i think it might be coming from the axle coming out but couldnt make out if it was from there. how hard is it going to be to replace all the seals and would it hurt to drive with this leak as long as im not using my 4x4. i was also thinking about putting a straight axle on this truck because what i have been told you have to take the whole ifs apart to fix that seal. what all will i hvae to do to swap these out. i have leafs on the front already. thank you
