Ignition upgrade questions
What can I do ignition wise to liven up my engine a little bit? I was looking at MSD's Blaster ignition PN 5900.
www.msdignition.com/ignition_1_5900.htm
Is this a decent model and will it fit the truck in my sig?
Also, is an MSD coil a good thing to go along with this?
http://www.msdignition.com/coil_blas..._8202_8223.htm
Will these thing go together as a system?
I'm just playing around with this and would like to try this.
Thanks
If you want any improvement, you could upgrade to the MSD6A, capacitive discharge unit. I have heard good things about this unit. Being it's a capacitive discharge system, you will get more voltage, plus it has multiple sparks at low rpm. The low rpm is where I am hearing people are happy with it.
