Sponsored by: Real Truck
Front Axle/Hub Question
Old Jan 30, 2007 | 11:37 AM
Jim59's Avatar
Jim59
Check out the Ball Joint Replacement thread in the tech file. In there will be part numbers for all the seals .... maybe this will help to clear it up?
Jim
Old Jan 30, 2007 | 11:38 AM
99f350sd's Avatar
99f350sd
Small Knuckle Seal or "Dust Seal"
Ford # F81Z-1S175-HCA $15.46 each
NAPA # 21918 $8.99 each
National #710413 $7.84 each
Large Knuckle Seal or "Oil Seal" (pressed on with special tool)
Ford #F81Z-3254-CB $26.54 each
NAPA N/A N/A
Old Jan 30, 2007 | 11:58 AM
Seatow's Avatar
Seatow
I know I need the large seal, where is the small one?
Thanks
Chad
Old Jan 30, 2007 | 12:00 PM
99f350sd's Avatar
99f350sd
The one on the other side of the ujoint.
Old Jan 30, 2007 | 12:03 PM
Seatow's Avatar
Seatow
You mean the one that seals the end of the axle tube?
Old Jan 30, 2007 | 12:06 PM
99f350sd's Avatar
99f350sd
Yes sir it just a dust seal. you will have the axle out so you should replace it. It goes on the axle. You need a tool for the big seal. Don't try to do it without it or have the dealer install the seal 4 U.
Old Jan 30, 2007 | 12:09 PM
Seatow's Avatar
Seatow
Sir you have been more than helpful. Many thanks. 5 minutes on the forum beats the hell out of the first half of the day gathering blank stares at the dealership and every parts store around.
Thanks
Chad
Old Jan 30, 2007 | 12:11 PM
99f350sd's Avatar
99f350sd
I will send you a link with pictures so you can see what to do if I had your email address. Also now is the time to do ball joints if they are worn.
Old Jan 30, 2007 | 12:12 PM
Seatow's Avatar
Seatow
cjw0321@msn.com
Thanks
Old Jan 30, 2007 | 10:00 PM
Seatow's Avatar
Seatow
Thanks Dick. I got the passenger side done this afternoon. I was really getting the run around on parts. Apparently whoever supplied the oil seals in 2000 didn't share their part #s with Ford?????? Anyway, with your part #s I was able to make short work of the job. I am going to attach the easy side (driver) next mon.
Old Jan 30, 2007 | 10:04 PM
99f350sd's Avatar
99f350sd
When you install the axle slime it with grease on the end so you will have a easy install through the diff seal way in there. You don't want to rip it.
Dick
Old Mar 6, 2007 | 08:22 PM
Redonthehead's Avatar
Redonthehead
I found this thread on a search for a concern I have. Sounds like the same thing. Also found this photo on guzzle's site which shows the exact concern I have but doesn't reference it.
Note the seal(?) to the right of the rachet head. It looks loose on the shaft like mine does when the front wheel is turned to the side. Its inboard of the u-joint where the front shaft goes into the housing. Is this something I need to drop everything and fix before driving the truck? I assume its a big job requiring the front propshaft to be pulled out.
Old Mar 6, 2007 | 08:27 PM
  #28
99f350sd's Avatar
99f350sd
See how much your axle moves up and down. Your needle bearings may be shot or maybe just the seal is toast. Its a dust seal..You should pull it all apart and check all.
Dick
Old Mar 6, 2007 | 08:50 PM
  #29
mountngoat's Avatar
mountngoat
the seal you are questioning is only a dust seal and does not actually fit into the axle tube it is pressed up against it by the axle shaft. jack up the truck and check for bearing play or ball joint slop. if you have neither i would'nt pull it apart just for that dust seal. How close to a 60,000mile service of the needle bearings are you?
and of course this is just my opinion.there is an actual oil seal inside the axle tube just past the diff carrier to keep diff lube in and dirt and grime out. in the tech section there is a great article on ball joint replacement it will tell you all you have to do to get to that seal good luck
Old Mar 6, 2007 | 10:08 PM
  #30
guzzle92's Avatar
guzzle92
The reason I did not reference it is because of the poor design of the seal. The majority of the 4x4 SD's running down the roads will look like this. mountngoat is correct that it is simply a dust seal that does not seem to affect the wear or performance of the axle to any degree. I'll replace them when the time comes for ball joints.
