Vacuum problems with 351?
Old Jan 24, 2007 | 02:35 PM
kf4mgz's Avatar
kf4mgz
I've got a 1989 F250 with a 5.8 (351W) engine. Lately, I've had problems with the engine surging, and stalling. Today I checked the air filter, and the it had a lot of oil inside the box. Without the filter it runs fine, so I'll replace the filter. I put this filter in maybe 3 months ago though. I've also had problems with an oil leak, from multiple locations, it appears. I know some of the vacuum hoses have been disconnected recently, when I had work done on the trans. Could the vacuum hoses be causing a problem? Too much pressure inside the engine blowing oil out? Just wondering and thanks in advance for any advice!
Old Jan 24, 2007 | 05:56 PM
obars's Avatar
obars
Lots of oil in air filter is not a good sign... Sounds like oil blowby. Is engine using oil?? Check pvc valve and fittings/hoses.
Old Jan 24, 2007 | 06:18 PM
kf4mgz's Avatar
kf4mgz
I'll check the pvc valve... I've had the truck for about 4 years, and have never even found the pvc valve... I'll check it out. Thanks!
Old Jan 26, 2007 | 01:16 PM
kf4mgz's Avatar
kf4mgz
I've replaced the pcv valve, but old one seemed ok... replaced it anyway... truck runs pretty good now, but still haven't found oil leak, could be the seals... thanks again though!
Old Jan 26, 2007 | 04:12 PM
obars's Avatar
obars
How about the hose going to the PVC valve and also the brake booster may be leaking.
Old Jan 26, 2007 | 05:42 PM
kf4mgz's Avatar
kf4mgz
hoses to the pcv valve seem to be ok, but i'll check the brake booster too! thanks!
