auto door locks messed up
Old Jan 23, 2007 | 05:11 PM
exped03's Avatar
exped03
2003 expedition door ajar light stays on and doors lock except for drivers door. Battery gets run down. sometimes doors will lock after driving a while. Dome lights all stay on unless switched to off mode.
I checked all fuses and doors everthing is closed. Whats happening?
exped03
Old Jan 24, 2007 | 08:21 AM
dakota_viking's Avatar
dakota_viking
Unlike older trucks that have a push button switch for the dome lights, the new Ford trucks use a micro switch that is located in the door latch. Sounds like yours has gotten gummed up.
Give the latch a bath in WD-40, PB Blaster, Tri-Flo, something that will remove the gunk and get everything moving again.
Once the switch is working, the door should lock, the door ajar will go out and the dome light should work correctly.
For good measure, lube up all of the door latches.
Good luck!
Tim
Old Jan 24, 2007 | 12:14 PM
exped03's Avatar
exped03
dakota_viking
Hey Thanks Tim I am going to go try right now I will let you know.
And I will lube the rest of the door locks as well.
Lynn
mlrosenke
Electrical Systems/Wiring
Jul 17, 2010 04:34 PM
Blood85
22
Feb 4, 2010 10:23 PM
jco1385
Aug 28, 2007 11:02 AM
edb78
Jul 23, 2007 07:37 AM
dlm9591
Oct 9, 2004 05:54 PM
