General Automotive Discussion
2001 caravan fuse box
Old Jan 23, 2007 | 02:22 PM
wolfmanagh's Avatar
wolfmanagh
2001 caravan fuse box dash lights
anyone here know where the fuse box is located on a 2001 caravan?
I didn't see it under the dash but maybe I'm not looking in the right area.but that is it and all other lights outside and inside appear to work.
edit: I need to change my question.
The only fuse box appears to be under the hood. But our problem is there are no dash lights. The milage lights up and the station lights up on the radio
Old Jan 23, 2007 | 03:56 PM
trike1946's Avatar
trike1946
I'm only guessing here. We had an older one and the fuse box was on the side of the dash when you opened the drivers door. ????????
Old Jan 24, 2007 | 09:20 AM
wolfmanagh's Avatar
wolfmanagh
nope not there on this one. It's not even on the passenger side. Looks like right now I'll have to start looking at the switch and make sure it is working right.
Old Jan 24, 2007 | 04:41 PM
trike1946's Avatar
trike1946
How about in the glove box?
Old Jan 24, 2007 | 08:12 PM
smokestone52's Avatar
smokestone52
I have an 02 that was built in 01. Its in the engine compartment drivers side by the battery. I am pretty sure there is a fuse for interior and dash lights in that fuse-relay box. Hang on I will go look. Ok ya might check the fuse marked IOD, it is 15 amp.
Old Jan 25, 2007 | 01:35 PM
wolfmanagh's Avatar
wolfmanagh
I did check the IOD fuse and it was good I even pulled all the fuses out and put them back in thinking maybe a bit of corrosion.
Just a little bit ago I checked in to the headlight switch and came up with the thought that lights all go through a computer and the headlight switch is all done with resistance. So I took the ground off the battery for a bit and put it back on and the dash lights worked again.
